Thread: Recovery of R23
    Chris7's Avatar
    Chris7 Guest
    Recovery of R23
    Does anyone out there know the best way to recover a large amount of R23 other than just using a chilled evacuated high pressure cylinder?
    I cant find a recovery pump that is suitable for high pressure gasses of the type of R23,R508b etc
    C
    Oct 2003
    5,630
    Re: Recovery of R23
    Good question Chris, struggled exactly over this problem end last year and for me, it's impossible to do this.
    You have to vent it to the atmosphere unless you recover it to several cylinders and pressurize those all to 20 bar.
    11,025
    Re: Recovery of R23
    Previous thread on this subject came up with a few ideas...
    http://www.refrigeration-engineer.co...read.php?t=840
    Jan 2002
    PA
    10
    Re: Recovery of R23
    You need a high pressure recovery system like our SRS unit.
    Quote Originally Posted by Chris7 View Post
    C
    Peter Coll
    Neutronics Inc.
    3,355
    Re: Recovery of R23
    Is the system you are recovering from operational ?
    Gramstrup's Avatar
    Gramstrup Guest
    Re: Recovery of R23
    You may already have solved the problem, but anyways here is a way to recover the most.
    if possible freeze your recovery cylinder to the lowest possible, if you have access to low temp freezer, then use this, alternative a cold room.
    the trick is simply to let the refrigerent run from the warm unit to the cold cylinder, best result is if you can have your cylinder keept in the cold, it will take some pretty long time
    it a long distance i on site simply make !/4 pipe between
  1. Is this normal with a CR 700 recovery unit?
    By AlexLPD in forum Trouble Shooting
    Last Post: 13-04-2010, 07:40 PM
  2. Is Air Content Analyzer Required on Recovery Cylinder?
    By A1_Autos in forum Air Conditioning
    Last Post: 26-03-2010, 07:48 PM
  3. Can ITE Mini R Recovery Unit recover Liquid?
    Last Post: 22-03-2010, 11:51 PM
  4. complete System Recovery
    By absolute-zero in forum Computers & the Internet
    Last Post: 20-01-2008, 06:03 PM
  5. Recovery and vacuum equipment
    By Larry2 in forum Fundamentals
    Last Post: 19-07-2006, 12:16 AM
