Results 1 to 1 of 1
24-03-2010, 03:22 PM #1
High state compressor oil pressure trip
Hi all, i am new here, wish you guys can give me some ideal and guideline regarding the refrigeration system.
i am troubleshooting a environmental test chamber with cascade system ( H/S R404A, L/S R23, water cool). the problem of this chamber is H/S compressor oil pressure trip.
i couldnt find any problem with H/S refirgeration system, but i found there is a insufficient refrigerant for L/S refrigeration system which is cause by leakage at the compressor discharge service valve.
i fix the leakage and top up R23 for the L/S refrigeration system and i found the H/S working well with no oil pressure trip.
My question is, will the L/S refrigeration system with insufficient gas cause the H/S compressor oil pressure trip, if yes? how?
Leak Testing?
By Thana in forum Trouble ShootingReplies: 36Last Post: 31-08-2010, 02:57 PM -
discharge pressure too high
By zahar in forum Trouble ShootingReplies: 7Last Post: 16-02-2008, 08:58 PM -
Benji
By benji in forum Trouble ShootingReplies: 29Last Post: 30-01-2008, 01:25 PM -
fun quiz
By Brian23 in forum New to REReplies: 6Last Post: 02-10-2007, 10:18 PM -
high pressure protection
By karimihassan in forum Air ConditioningReplies: 11Last Post: 18-08-2007, 06:52 PM
