    Dec 2009
    New Zealand
    44
    67
    9
    Submerged Oil Cooling (PC in a tank)
    Hey guys , i have seen this done on a couple of websites and would like to give it a go on an old pc that i have. I have the fish tank ready and i have a good supply of Polyolester oil but everyone i have seen is using mineral oil.
    I know that poe acts as a solvent ,would it be to harsh on electronics ?? any advice appreciated
    cheers Andy
    69
    10,484
    Re: Submerged Oil Cooling (PC in a tank)
    Would it be wise to have that type of oil exposed to the atmosphere?
    "They, POE, are highly hygroscopic and absorb water which is almost impossible to drive out."
    Split Croatia
    6,103
    7
    30
    Use good old transformer oil.
    Dec 2009
    New Zealand
    44
    67
    9
    POE will absorb up to 2500ppm from the research that i have done. Is this a significant amount of water? , i dont think so , so i am willing to give it a go on an old pc for starters and see how it runs.
    I have a condenser that i am going to pump oil through for cooling when it reaches a certain temp in the tank.
    Jul 2010
    usa
    34
    This is a great post.It helps me to increase my knowledge.
    jim01
    Jul 2010
    usa
    34
    Thanks for your post.
    jim01
    Sep 2005
    36
    119
    13
    I did this years ago... I was only about 13 at the time...
    I took a standerd upright fridge freezer... and chopped the freezer off the top of it... then lay it on it's back so it was like a mini chest freezer...
    then I stripped down a small undercouter freezer (carefull not to damage any pipes etc..) and used that to cool the oil... (I cut out a small chunk at the door of the dreezer to put the pipes through)
    installed my pc in the box... then filled it with about 7 gallons of oil... standerd diesel engine oil (from my fathers garage)
    it worked really well.. and would go down to -30'C
    only problem was, the oil was very thick at that tempriture so the oil around the cup etc.. would heat up while the rest of the oil was still at -30'C
    water/moisture wasn't a problem... any moisture getting in froze and dropped to the bottom of the box... every few weeks I'd put a thick plastic bag on my hand/arm and reach in to pull it out.... wow that was cold
  1. Replies: 2
    Last Post: 08-12-2008, 10:34 PM
  2. Replies: 0
    Last Post: 08-12-2008, 03:20 PM
  3. How an expansion tank works?
    By Raadster in forum Fundamentals
    Last Post: 25-07-2008, 02:25 PM
  4. Compressor loading, cooling, and range of operation.
  5. A/C not putting out enough cooling, gauges not happy
    By Larry2 in forum Air Conditioning
    Last Post: 13-11-2006, 09:32 PM
