Thread: fridge problem
17-03-2010, 05:15 PM #1
fridge problem
just changed a stat like for like on a two door fridge freezer only to find that the milk is now freezing in the fringe compartment on the lowest setting does anyone have any idea why
17-03-2010, 07:27 PM #2
Re: fridge problem
is your stat set too low¿
17-03-2010, 07:53 PM #3
18-03-2010, 01:18 PM #4
Re: fridge problem
It doesn't cut out, improper placement of bulb, if it's a cap tube system place it near the cap tube area, away from the fan, the coil gets colder in theat area, if that doesn't do it, take it out, put it in the freezer and see at what temp there is no countinuity (sp), or if it ever opens, I have seen bad brand new T-Stats.
26-03-2010, 06:54 AM #5
Re: fridge problem
Its not cycle, is the stat the correct one.checked the cut out temp, is the bulb in the right location,checked the connection on the stat,use your emagination its easy.
CPC 240 FF GB Fridge freezer Problem
By S1RDG23 in forum DomesticReplies: 1Last Post: 02-01-2010, 05:52 AM -
LG Fridge problem
By BigMinge in forum Trouble ShootingReplies: 11Last Post: 22-11-2009, 12:30 PM -
Hotpoint Mistral Fridge Freezer Plus. Fridge won't cool
By Redmeister in forum Trouble ShootingReplies: 2Last Post: 09-07-2009, 06:25 PM -
help- my bar fridge is wacko?!
By ben in forum Trouble ShootingReplies: 3Last Post: 25-01-2002, 12:06 AM
