Results 1 to 2 of 2
Thread: PTC Probes
17-03-2010, 01:11 PM #1
PTC Probes
I need to change a probe that on the diagram states it's a PTC 1000, are all PTC probes 1000? as I have one that is labelled up as just a PTC can i use this one?.
17-03-2010, 06:08 PM #2
Re: PTC Probes
Hi boulting.
There are normally 2 ranges.
PTC 100 and PTC 1000.
The 100 gives 100 ohms resistance at 0c and the 1000 gives 1000 ohms resistance at 0c.
There are tables available for either probe giving the relevant resistances for given ambient temperatures.
So they are easy to check.
There are others with differing ranges and also an NTC range.
Just google PTC and you should find some charts to help!
Cheers Grizzly.
transducers and probes, the differences?
By bill1983 in forum ElectricalReplies: 7Last Post: 06-09-2009, 09:34 PM -
NTC temperature probes in parallel. How?
By desA in forum New TechnologiesReplies: 23Last Post: 29-05-2009, 06:38 AM -
LG the trail of faulty probes
By Chris2005 in forum Air ConditioningReplies: 17Last Post: 15-02-2009, 06:19 PM -
gram probes
By richelli in forum CommercialReplies: 6Last Post: 06-06-2008, 12:13 PM -
Electronic controller probes wired wrong
By Electrocoolman in forum Trouble ShootingReplies: 3Last Post: 12-11-2007, 06:39 PM
