Results 1 to 2 of 2
Thread: Buffer tank size selection
17-03-2010, 09:44 AM #1
we have such situation: heat pump is heating convectors in domestical property (water volume is about 100 Litres ). There is factory fitted circulateing pump installed inside heat pump, and for this small water volume it seems too big...as circ.pump gets hot and noisy (presure is ~0,5 bar). The sugested solution is to increase presure by installing buffer tank on return side before the heat pump, but what volume it should be ? The point is to reach 1-1,5 bar so the factory preinstalled pump will work at nominal conditions and will not be hot and noisy. Thanks
(Also notice : diameter of copper pipes - 22 mm, convectors - 16 mm )
17-03-2010, 02:52 PM #2
Re: Buffer tank size selection
Fitting a buffer vessell will not increrase the pump pressure, it might increase the resistance however.
What is your pressure gauge reading, pressure across the pump or simply pressure within the system?Brian - Newton Abbot, Devon, UK
Buffer Tank Sizing
By deepakrbhat in forum FundamentalsReplies: 12Last Post: 12-02-2010, 09:31 AM -
Buffer tank
By ginger jiang in forum Heat PumpsReplies: 0Last Post: 27-02-2009, 08:06 AM -
Calculation bypass buffer tank volume
By abbasi in forum New TechnologiesReplies: 3Last Post: 16-10-2008, 06:19 AM -
Bypass buffer tank volume
By abbasi in forum Technical SpeculationsReplies: 3Last Post: 15-10-2008, 05:28 AM -
Where Do I Locate a Buffer Tank?
By Jethro Bush in forum Air ConditioningReplies: 7Last Post: 25-12-2007, 03:23 PM
