16-03-2010, 10:44 PM #1
Sea containers for a freezer box.
Has everyone got a reason not to use one of these containers (after insulating it) for a freezer box? and suggestions how to set it up. or anyone doing it.
17-03-2010, 11:27 AM #2
Re: Sea containers for a freezer box.
do you see them everywhere?most things are possible everyone,treat it like planting a tree.
17-03-2010, 07:33 PM #3
17-03-2010, 08:11 PM #4
Sea containers are badly insulated. Only 75 mm polyurethane.
If you want to use it as a freezer, I recommend you to increase the insulation by an extra cover of 75 plates.
If you are thinking of using the steel ones, then building a proper freezer using insulated panels is cheaper and better.
18-03-2010, 12:39 AM #5
yes done a few dry containers,lined out with panels,6 inch put slab doors heater strip/door heater,they are a bit tight for evap,heater replacement would mean removing coil ,fit new equipment everytime make sure you user a container in good condition you do not want water ingress.
Blast Freezer Within Freezer
By rickmor in forum Technical DiscussionsReplies: 4Last Post: 18-06-2009, 03:37 AM -
ice cream truck freezer
By GaryC in forum TransportReplies: 7Last Post: 06-12-2008, 02:19 AM -
Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
By sumnerpa in forum Trouble ShootingReplies: 1Last Post: 19-08-2008, 03:16 PM -
Freezer compressor running 20 Hours/day
By rickcw in forum DomesticReplies: 12Last Post: 08-03-2008, 11:50 PM -
Trolley freezer & blast freezer
By smpsmp45 in forum NH3Replies: 0Last Post: 25-08-2007, 07:29 AM
