Thread: York chiller cooling capacity
14-03-2010, 09:30 PM #1
Can any body help please, maybe york rep or ex-york, i maintain a large, very old (1978) York chiller, it;s model number is LCHH160 wl 50p
I'm trying to determine the duty in Kw, i have an incling that the Yorks back then used the Tonnage of system, i.e 160 tons of refrigeration!! as this model sudgests. 1 ton = 3.5kw approx. Would i be right in assuming this unit is a 160 on system,
Look forward to replys, many thanks
Bustings
24-03-2010, 07:04 PM #2
Re: York chiller cooling capacity
hi, if chiller with JS84 = 100 onwards
js83 = 84 - 125 tr
25-03-2010, 07:50 AM #3
If I cant determine a compressor capacity, I'll often look at what exspansion device is attached, and use it, and the refigerant used to determine capacity of compressor. The assumption being that the people that built the system knew what they were doing.
York Chiller problems
By ingherrera in forum CommercialReplies: 18Last Post: 26-07-2011, 03:10 PM -
york chiller oil
By 1mikeefc1 in forum Technical DiscussionsReplies: 0Last Post: 24-07-2009, 03:59 PM -
York Chiller Fault
By kifayat in forum Trouble ShootingReplies: 8Last Post: 11-07-2009, 02:55 PM -
Working on chiller, for cooling paper rolls, need advice
By bharatbaldwa in forum FundamentalsReplies: 4Last Post: 27-05-2009, 03:49 AM -
need help on YORK chiller
By nassersh in forum CommercialReplies: 4Last Post: 16-12-2008, 12:47 PM
