Thread: Open Type Display Coolers
13-03-2010, 06:29 AM #1
Hi Everyone
How to calculate heat load of Open Type display coolers? (Like the ones normally seen in Super markets)
Thanks in advance
With regards
Rayin
13-03-2010, 06:49 AM #2
13-03-2010, 08:18 AM #3
Re: Open Type Display Coolers
Hi Toosh,
Thanks for your quick reply. If I purchase an open type display, can I get information how the mabufacturer calculated the heat load?!. I am not going to use the unit, but I would like to know how the heat load is calculated in those units. In refrigeration books as well as on the web pages, it is explaining the calculation for an insulated, all sides closed rooms/ cabinets. But never seen one for display units with one side open. So may be some one can explain
Rayin
13-03-2010, 10:49 PM #4
Consider the front as a side with a very large heat loss.
14-03-2010, 05:52 AM #5
Thank you Brian_UK, but what about the "K" value for the "air wall"?
OR Can we calculate the heat load using air change factor taken as 2 or 4 fold of heavy usage?. What is general practice?
Kevry open display case freezing up
By mastercheif602 in forum Trouble ShootingReplies: 8Last Post: 08-02-2010, 07:22 AM -
shaft keyway repair in open type compressor
By coldkeeper1 in forum Supermarket RefrigerationReplies: 6Last Post: 20-10-2008, 03:47 AM -
Teddington display type etr 1rc probe
By Robfridge in forum CommercialReplies: 1Last Post: 19-01-2008, 03:03 AM -
Oversize Piston in Open Type Recip. Compressor
By imranmd in forum CommercialReplies: 29Last Post: 29-07-2007, 07:04 PM -
Open Type Compressors
By shogun7 in forum Air ConditioningReplies: 1Last Post: 07-01-2005, 09:15 AM
