    SQUATCH1's Avatar
    SQUATCH1 Guest
    Frick TDSH 355 oil press. problems
    I have a Frick TDSH 355 that has an oil pressure trouble, this is a well used machine and has over 40000 hrs on it, and has had very little work/service done on it.My service tech has called Frick and they are hardly any help, any suggestions?
    Auckland
    74
    3,357
    37
    Re: Frick TDSH 355 oil press. problems
    Check the oil filters would be a good start.
    magoo
    SQUATCH1's Avatar
    SQUATCH1 Guest
    Yep , done it, I have been all over this machine, I am thinking it is enternal, I ahve two with low oil pressure.
    Jan 2006
    Croatia
    68
    2,261
    31
    Hi, SQUATCH1
    Quote Originally Posted by SQUATCH1 View Post
    how low is your oil pressure no data from you ...
    what happen when compressor stops .... which alarms you have ....
    this is guessing......
    ..... Discharge temperature very low. Oil temperature low and oil may be foaming in oil separator
    ..... Excessive liquid in suction line / liquid slugging. Check evaporator and economizer and expansion valve function.
    ..... Liquid injection overfeeding. .....Check the settings in control system (increase the set point). Check the stability of the liquid injection.
    ..... Oil pressure rapidly drops off when compressor starts. Results in compressor differential alarm Main oil injection throttling valve too wide open or oil pressure regulating valve improperly adjusted. Readjust both valves.
    ..... Oil pressure fluctuates. Liquid injection overfeeding or refrigerant flood back from system. Make necessary adjustments or corrections.
    maybe will help a little ... possible not ... after 40000 working hours
    Best regards, Josip
    Jul 2007
    Czech
    61
    374
    Sorry gentlemen, 40 000 hours?, overhaul.
    The tightness of the valve certainly does not work, balance piston? large loss of oil pressure.
    Feb 2010
    usa
    21
    This big girl has the two stage/dual feed to the balance piston, i think. That may be the easiest solution. 40k is high, if you can't pull it, you should budget for a re-man before you're stuck.
  1. frick scew cuts out lo oil press
    By marley in forum Industrial
    Last Post: 12-05-2010, 02:25 AM
  2. Frick TDSH 233 short
    By squidward in forum Industrial Compressors
    Last Post: 04-09-2009, 08:33 PM
  3. Frick TDSH 355 l or PDSH 355L
    By Peter_1 in forum Industrial Compressors
    Last Post: 13-03-2009, 05:26 PM
  4. FRICK TDSH 233 Slide Valve and guide damaged
    By 404cab in forum Industrial Compressors
    Last Post: 30-07-2008, 11:24 PM
  5. Frick RWB II 177H 400 Hp problems
    By warrenbuddy in forum Trouble Shooting
    Last Post: 03-04-2008, 06:15 PM
