Results 1 to 13 of 13
    Mar 2010
    US
    49
    7
    Question Working on the international system. Im confused
    Hey how u doing?
    I’m moving soon from US to down under and I’m trying to get my mind used to work in the international metric system so I have a couple of question and I 'd appreciate for your help.
    Ok I know that temp is measure with C Celsius instead of F. But I've been reading some posts and articles on the net and when they talk about subcooling or superheat they talk about "K" ???
    For example this is from an article “liquid subcool values of say 1K to 3K”. What do they mean by this?? Is this 1 kelvin to 3 kelvin? Why are they using Kelvin instead of Celsius?
    I’ve seen also that in some articles they use celsious and Kelvin interchangeably.
    But 23 C are not the same as 23 K, are they?? I thought that C=K-273
    Can someone help me to digest this please.
    I have 2 more questions.
    1. What unit is used in Aussie to measure refrigerant pressure? Psi??
    2. How is airflow measured in Aussie? CFM??
    Thanks.
    Nov 2004
    China
    176
    Re: Working on the international system. Im confused
    Forget about American units of measure. They aren't used anywhere else except sometimes in Canada. Pressure is recorded in bar or kpa. Degrees Kelvin is an absolute scale starting at -273 C but one degree C difference is the same as 1 degree K. Air flow is recorded in cubic meters per second or per hour. Water flow is recorded in litres per second or lcubic meters per hour. refrigeration effect and motor power are in kW. The best way is to start using the international units & don't try to convert everything. The calculations are way easier & you'll fit in and become comfortable much faster.
    Jan 2006
    Croatia
    68
    2,263
    31
    Hi, elgue
    Quote Originally Posted by elgue View Post
    Hey how u doing?
    Thanks.
    Welcome to RE forums ....
    you can find and learn a lot by searching RE forums....
    use key words like superheat, subcooling, measuring units, Kelvin etc...
    read this thread:
    http://www.refrigeration-engineer.co...ad.php?t=23821
    of course, welcome back with any new doubt you have
    good luck down under....
    Best regards, Josip
    Nov 2005
    New Zealand
    550
    Hey how u doing?
    Thanks.
    Here is si units
    http://www.gordonengland.co.uk/conversion/thermcon.htm
    My wife used to say you never listen to a word I say at least I think that what she said
    Apr 2008
    canada
    75
    94
    B”H
    Charlie,
    Engineers like to work in bars.
    Mar 2006
    Lancashire
    1,859
    28
    Hey how u doing?
    Even though K normally stands for Kelvin, people use the term K on the end of a number to express temperature differences.
    For example Saturated Condensing temp of 56DegC and the actual temperature of the liquid line is 48DegC, this would give you 8DegC subcooling or 8K ( temperature difference.
    Marc
    Nov 2005
    New Zealand
    550
    Quote Originally Posted by michaelm View Post
    B”H
    Charlie,
    Haha is that your local bar or pressure
    Nov 2004
    China
    176
    Quote Originally Posted by Toosh View Post
    Your choice. I like both.
    Mar 2010
    US
    49
    7
    Hey Thanks to everyboby for taking the time to answer my questions.
    Does anyone know where I can find a P/T chart on the web for Celsius and bar or Kpa??? I've been trying to find one and all I find are P/T charts with F and Psi.
    By the way any good HVACR book (basics) with the SI system you would recomend?
    Jun 2007
    At sea
    367
    Mar 2006
    Lancashire
    1,859
    28
    Kotza Refribase
    Marc
    Nov 2004
    China
    176
    here's a PT guide for the "400" refrigerants. I have one for ammonia, R22 & R507 but it's too big to upload
    Attached Files Attached Files
    Nov 2005
    New Zealand
    550
    Try this
    http://fridgetech.com/calculators/
  1. How to determine the suitable air-conditioning system
    By Terrywarner in forum Air Conditioning
    Last Post: 15-05-2010, 08:14 PM
  2. High oil temperature in wet screw system
    By desaipt2003 in forum Trouble Shooting
    Last Post: 18-11-2009, 01:04 AM
  3. Over charged system... what symptoms?
    By Clk320_Greg in forum Trouble Shooting
    Last Post: 19-10-2009, 06:25 PM
  4. Automotive A/C Vent Temp Range vs System
    By Don Browney in forum Air Conditioning
    Last Post: 15-05-2002, 06:19 AM
