Results 1 to 15 of 15
11-03-2010, 09:26 AM #1
I need all your helps. F62WBH MYCOM of mine broken
Hu hu hu....
Help me pls...
I have 02 new MYCOM comp. Model F62WBH
Oil pump fault, then all parts inside was broken
CAN I buy spares of WB model to REPLACE for WBH model ???
Could AnyOne answer me please !!!?
It's so URGENTLY. It's just 02 times of starting, then....
11-03-2010, 12:08 PM #2
Re: I need all your helps. F62WBH MYCOM of mine broken
we get our spares for mycom compressors from comtec 01215587757 try them
11-03-2010, 02:13 PM #3
11-03-2010, 07:03 PM #4
Most parts are the same like pistons , valves , big end bearings .
Seal , main , thrust bearing , oil pump are different .
There must be a Mycom ( Mayekawa ) agent somewhere near you !
What damage do you have ?
11-03-2010, 07:12 PM #5
12-03-2010, 12:50 AM #6
@ RANGER1
Thanks for your informations
Could you pls listed here all differences between WB and WBH ( Also WA and WAH ...). Thanks so much!!
The oil pump and oil pressure swicth are fault, so ac ac ac ......all parts inside compressor was broken
@ Toosh
I also contact MYCOM Vietnam, but they're only Sale office, they sell comp. and Unit, NOT sell spares, AND can not get technicals help from them
DEAR ALL
Pls advice me, tell me where can i got MYCOM origin parts and also have fully technic help.
Thanks!
12-03-2010, 01:00 AM #7
If everything inside busted, your quickest and cheapest option is replace the whole compressor.
magoo
12-03-2010, 01:05 AM #8
Try this one
http://mycomasia.com/contact.htmlMy wife used to say you never listen to a word I say at least I think that what she said
12-03-2010, 01:59 AM #9
What are you using the compressor for refrigeration or gas compression? I have worked on Mycom recip compressors a long time and don't remember the H designation. It usually means high pressure duty. High pressure compressors have needle bearings on all the wrist pins instead of only on the high stage pistons. catastrophic failures are liquid or oil pressure related. Compound compressors tend to have problems with the inter-cooling between the stages causing the high stage pistons being slugged(too cold) or starved and running hot causing the plates to break which allows re-compression super heating. Before i would risk a new compressor i would look at the package and check everything. Are there any undamaged parts? The crank can be turned and install over sized rod inserts .015'' or .030'' over.
12-03-2010, 02:45 AM #10
Dear Magoo
Yes, it's the BEST WAY
But, about technical side. I still want to know, CAN we use WB spares for WBH model ???
And, what parts same, what parts different ????
Dear Toosh
I also already try this contact, but have no reply now
Dear la461
This comp. using in Freezing Vacuum system (-45oC) - Fresh Vegetable and Fruit factory
I have check ev'rything OK, Only Oilpump fault first, so bearing half, mechanic shaft seal, double shaft seal, main bearing DAMAGEDLast edited by avico; 12-03-2010 at 02:47 AM.
12-03-2010, 06:15 AM #11
Try Mycom office in Shanghai. email is ailsa-wong@mayekawachina.com.cn or weichen@mayekawachina.com.cn.
Basically, the WBH machine is a newer version of the WB. Many parts are the same but most bottom end parts are different.
12-03-2010, 02:13 PM #12
15-03-2010, 01:26 PM #13
Mayekawa Singapore Pte. Ltd.
6 Tagore Lane Singapore 787470
Tel: (65) 6451-1565 / Fax: (65) 6451-4932
Mayekawa Mfg. Co., Ltd. (Vietnam)
Tel: (84) 8-825-6917 / Fax: (84) 8-825-6919
15-03-2010, 05:30 PM #14
- Sep 2009
- Iran
- 66
- 672
- 1
- 19
if you could not find it inform me I have second hand of that in my work shop.
21-03-2010, 05:32 AM #15
Dear mbc,
I still need it
Pls tell me your email address
Will send you the list of parts
or
Could you pls take some photos then email me: info@avico.com.vn]
Thanks much
Dang Anh Tuan
AVICO HVAC/R CENTER
