Results 1 to 15 of 15
    avico's Avatar
    avico Guest
    Unhappy I need all your helps. F62WBH MYCOM of mine broken
    Hu hu hu....
    Help me pls...
    I have 02 new MYCOM comp. Model F62WBH
    Oil pump fault, then all parts inside was broken
    CAN I buy spares of WB model to REPLACE for WBH model ???
    Could AnyOne answer me please !!!?
    It's so URGENTLY. It's just 02 times of starting, then....
    Mar 2009
    leominster
    Re: I need all your helps. F62WBH MYCOM of mine broken
    we get our spares for mycom compressors from comtec 01215587757 try them
    avico's Avatar
    avico Guest
    Quote Originally Posted by INKYMART123 View Post
    Dear INKYMART123
    i can't found COMTEC website also their contact
    Pls help me!!!
    AND
    I also want to know: CAN I USE F62WB'S SPARES FOR F62WBH MODEL ??????
    3,356
    Most parts are the same like pistons , valves , big end bearings .
    Seal , main , thrust bearing , oil pump are different .
    There must be a Mycom ( Mayekawa ) agent somewhere near you !
    What damage do you have ?
    Nov 2005
    New Zealand
    550
    Quote Originally Posted by avico View Post
    Hu hu hu....
    Help me pls...
    Try here
    Vietnam
     Hochiminh Room 305, 3FL, Tuoi Tre Tower, 60A Hoang Van Thu, Ward9, Phu Nhuan Dist., Ho Chi Minh City, Vietnam TEL:
    FAX: (84)8-3997-5284
    (84)8-3997-5287 Its Mycom
    Toosh
    My wife used to say you never listen to a word I say at least I think that what she said
    avico's Avatar
    avico Guest
    @ RANGER1
    Thanks for your informations
    Could you pls listed here all differences between WB and WBH ( Also WA and WAH ...). Thanks so much!!
    The oil pump and oil pressure swicth are fault, so ac ac ac ......all parts inside compressor was broken
    Quote Originally Posted by Toosh View Post
    Try here
    Vietnam
    Toosh
    @ Toosh
    I also contact MYCOM Vietnam, but they're only Sale office, they sell comp. and Unit, NOT sell spares, AND can not get technicals help from them
    DEAR ALL
    Pls advice me, tell me where can i got MYCOM origin parts and also have fully technic help.
    Thanks!
    Auckland
    74
    3,357
    37
    If everything inside busted, your quickest and cheapest option is replace the whole compressor.
    magoo
    Nov 2005
    New Zealand
    550
    @ RANGER1
    @ Toosh
    DEAR ALL
    Thanks!
    Try this one
    http://mycomasia.com/contact.html
    Mar 2010
    Ft Worth, TX
    74
    Hu hu hu....
    Help me pls...
    What are you using the compressor for refrigeration or gas compression? I have worked on Mycom recip compressors a long time and don't remember the H designation. It usually means high pressure duty. High pressure compressors have needle bearings on all the wrist pins instead of only on the high stage pistons. catastrophic failures are liquid or oil pressure related. Compound compressors tend to have problems with the inter-cooling between the stages causing the high stage pistons being slugged(too cold) or starved and running hot causing the plates to break which allows re-compression super heating. Before i would risk a new compressor i would look at the package and check everything. Are there any undamaged parts? The crank can be turned and install over sized rod inserts .015'' or .030'' over.
    avico's Avatar
    avico Guest
    magoo
    Dear Magoo
    Yes, it's the BEST WAY
    But, about technical side. I still want to know, CAN we use WB spares for WBH model ???
    And, what parts same, what parts different ????
    Try this one
    []mycomasia]
    Dear Toosh
    I also already try this contact, but have no reply now
    Quote Originally Posted by la461 View Post
    Dear la461
    This comp. using in Freezing Vacuum system (-45oC) - Fresh Vegetable and Fruit factory
    I have check ev'rything OK, Only Oilpump fault first, so bearing half, mechanic shaft seal, double shaft seal, main bearing DAMAGED
    Nov 2004
    China
    176
    Try Mycom office in Shanghai. email is ailsa-wong@mayekawachina.com.cn or weichen@mayekawachina.com.cn.
    Basically, the WBH machine is a newer version of the WB. Many parts are the same but most bottom end parts are different.
    avico's Avatar
    avico Guest
    Quote Originally Posted by charlie n View Post
    Thanks Charlie
    I'll try this contact
    Maybe they can help me solve problem
    mayekawa's Avatar
    mayekawa Guest
    Mayekawa Singapore Pte. Ltd.
    6 Tagore Lane Singapore 787470
    Tel: (65) 6451-1565 / Fax: (65) 6451-4932
    Mayekawa Mfg. Co., Ltd. (Vietnam)
    Tel: (84) 8-825-6917 / Fax: (84) 8-825-6919
    Sep 2009
    Iran
    66
    672
    1
    if you could not find it inform me I have second hand of that in my work shop.
    avico's Avatar
    avico Guest
    Quote Originally Posted by mbc View Post
    Dear mbc,
    I still need it
    Pls tell me your email address
    Will send you the list of parts
    or
    Could you pls take some photos then email me: info@avico.com.vn]
    Thanks much
    Dang Anh Tuan
    AVICO HVAC/R CENTER
