Results 1 to 2 of 2
Thread: Chiller operation best practice
10-03-2010, 08:20 PM #1
Hey guy's
I work at a facility with multiple chiller plants, they are typically manually controlled and I have been asked to program our BAS system to controll the chiller in one plant. I intend to run the chilled water pumps for freeze protection and obviously for chiller operation, I intend to run the chiller any time the OAT > 50 degF and the building is occupied and any of the space temperatures are above set point. I also intend to run the chiller when the OAT > 50 the building is not occupied and the temperature at any sensor is > 80 degF. and lastly I intend to run it any time the OAT is > 50 and the lab temp is high or the lab Rh is high. What do you guys think? am I on the right track? missing anything obvious? any suggestions or comments will be appreciated
10-03-2010, 08:23 PM #2
Re: Chiller operation best practice
don't forget 15 minute pump over run. Ie. if you disable the chiller, pumps carry on for 15 minutes as there may still be a refrigerating effect occuring as refrigerant stabalizes.
process chiller help
By talon771 in forum IndustrialReplies: 8Last Post: 12-01-2011, 08:42 PM -
VSD operation on a 15 kW scroll chiller
By jayaeros in forum ElectricalReplies: 22Last Post: 24-08-2009, 05:50 PM -
Absorption Chiller VS Mech. Chiller
By Intern in forum IndustrialReplies: 20Last Post: 30-05-2009, 08:31 AM -
Trane CVHE 450 R11 Centrifugal Chiller
By albertjoseph in forum Air ConditioningReplies: 4Last Post: 06-10-2008, 03:23 PM -
Trane Chiller low temperature operation
By Brads in forum IndustrialReplies: 2Last Post: 20-01-2008, 07:18 AM
