Results 1 to 14 of 14
    Feb 2010
    32
    A friend of mine told me...
    ...that I could build a vacpump using a domestic fridge compressor. My questions are:
    1) True or false
    2) Good idea or not. If not, why?
    Any other points you wish to raise, please do. I am learning all the time here & find these early stages of my refrigeration life challenging but very interesting so please be gentle with me.
    Apr 2001
    79
    5,071
    35
    Re: A friend of mine told me...
    1. True
    2. Better than nothing, not nearly as good as a real vacuum pump.
    Feb 2010
    32
    Hi Gary.
    I was just reading your refrigeration 11 thread & find your post easy to understand & informative. Keep up the good work.
    If I were to try to build one using a compressor, I assume that I would need one to use on R134a & another for R600a or would that not be strictly required?
    Also, any idea what sort of vacuum this method would achieve or is this like asking how long is a piece of string?
    Many thanks.
    Bobby.
    May 2008
    U.K.
    73
    Surely a vacuum is a vacuum? But hey, I've heard that the old compressor can be used as a vac pump. You'll also need a gauge to measure the vacuum and tightness of the system. Good luck.
    Apr 2001
    79
    5,071
    35
    Quote Originally Posted by Bobby Drake View Post
    Hi Gary.
    Many thanks.
    Bobby.
    I have never worked with R600a, so I'm not certain if that would be different.
    A compressor might get to 15-20 inches of vacuum, whereas a real vacuum pump will get well over 29 inches, down into the microns. There is really no comparison... but as I said, it is better than nothing.
    Way back before vacuum pumps were common, we used fridge compressors and did triple evacuations. It worked reasonably well... on the other hand, as soon as vacuum pumps became readily available, everyone ran out and bought one.
    Feb 2010
    32
    Hi Gary.
    The only reason I asked about different compressors for different refrigerents is to avoid any potential contamination of the system being vacced, say the system being repaired is R134a & if you are using an R600a compressor or vice versa. Or am I worrying over nothing?
    Apr 2001
    79
    5,071
    35
    Hi Gary.
    I wouldn't think that would make any difference. As soon as you start vacuuming, the system refrigerant vapor flushes through the compressor.
    11,025
    Hi Gary.
    Think of which way the molecules are being drawn, from the system via the pump to atmosphere.
    Backwards contamination should not occur unless you have a power failure and do not have a non-return valve in the line.
    Scotland
    327
    You should change the oil regularly in any vac pump, this may be tricky of you are using a small hermetic compressor.
    Hydrocarbons require a special safe handling certificate here in the UK and I think i'm right in saying you should be using dedicated equipment only.
    3,856
    Get a proper vac pump if you are working for other people, they rightly expect things to be done correctly when calling in a professional.
    If its some project for yourself then maybe a compressor would do but personally i'd still use a vac pump, especially on capiliary systems.
    Jon
    Jul 2008
    wet coast B. C.
    122
    The first refridgeration tech. I worked with had used a fridge comp. as a vaccumn. pump. He told me that the comp. did not last very long in this service. I would think that the comp. probably would overheat. Thus leading to its failure. C.D.
    NH3 for me
    Feb 2010
    32
    Thanks for the replies guys. I was pondering wheather to make one up just as a project really. I probably won't bother as it is probably a load of aggro for little benefit.
    Feb 2001
    Doncaster, England
    199
    'If you use a compressor as a vac pump, - hermetic compressors are piston type compressors and there will always be a gap at the top of the cylinder, even when the piston is at top dead centre. So this gas will never be pumped out of the compressor.
    Therefore you can never achieve a vacuum with a low enough pressure to boil off any water in the system.
    Typically water does not start to boil until you get down below 20 Torr (that is the pressure required to get water to boil at 20°C).
    If the temperature is lower then the pressure has to be lower.
    So get a vac pump!!!!!!!
    Tony
    Feb 2010
    32
    Quote Originally Posted by Tony View Post
    I have learned someting new there. Thanks for the info.
    I think I just might. Cheers.
  1. Advice needed for a friend
    By marc5180 in forum Training
    Last Post: 10-06-2009, 10:56 PM
  2. From me and the mine, to you and the yours...
    By The Viking in forum Chit Chat & Service Stories
    Last Post: 23-12-2008, 11:47 AM
  3. finding the net friend: lala
    By Crystal-426 in forum New Technologies
    Last Post: 20-06-2008, 02:55 AM
  4. Trying to help a friend out ident system
    By The MG Pony in forum Air Conditioning
    Last Post: 09-04-2007, 08:37 PM
  5. Your new friend
    By S.K.VARDE in forum New to RE
    Last Post: 21-06-2006, 09:07 PM
