Thread: Robinair VacuMaster Model 15401
10-03-2010, 06:38 PM #1
Does anyone know if this is any good to use on R600a?
10-03-2010, 06:58 PM #2
Re: Robinair VacuMaster Model 15401
It's a vacuum pump so unless it is used in an explosive environment then it should be OK.
If you are concerned about sucking a small amount of R600a through it then clear the system with nitrogen first. It probably would be in there anyway following your pressure test procedure.Brian - Newton Abbot, Devon, UK
10-03-2010, 07:07 PM #3
Cheers Brian. Believe it or not, we are not given any nitrogen ever. Don't ask me why, I am but a mushroom.
10-03-2010, 08:31 PM #4
Don't work for the same national firm as me perchance? I am also but a mushroom!!
10-03-2010, 08:35 PM #5
Hi Martin.
Who do you work for, mate?
Us mushrooms have got to stick together!
10-03-2010, 09:30 PM #6
OH NO! not more from Caril***n.
Model to Manufacturer Identification
By Lucas in forum Air ConditioningReplies: 5Last Post: 29-04-2009, 03:25 PM -
Fujitsu A0YR 18 LEC new model?
By kindanice in forum Air ConditioningReplies: 1Last Post: 22-01-2009, 07:57 PM -
Fan model for system optimization
By autt in forum System OptimizationReplies: 8Last Post: 31-03-2007, 05:34 AM -
Daikin Model
By Geofridgee in forum Air ConditioningReplies: 1Last Post: 12-07-2006, 09:23 AM -
UK TV Show looking for model makers / engineers
By roadshow in forum HobbiesReplies: 1Last Post: 30-12-2003, 03:16 PM
