Results 1 to 11 of 11
08-03-2010, 10:25 AM #1
Question about chillers for ice skating area
Hello Everybody,
I doing a little research, maybe you can help me,
I want to know how much will cost me a chiller for Olympic ice skating area, where i can find model, that suitable for my country ( middle east, 9 month of sun, in summer +35 ), maybe somewhere i can find forum with used chillers, that you can recommend, where i should be start looking ?
thank you very much
08-03-2010, 10:43 AM #2
Re: Question about chillers for ice skating area
Did you make a proper heat calculation?
How big is the rink? Hockey size or figure skating? How many seatings on the stands? How high is the dome?
Insulation of the skate rink is essential in summertime.
Freezing water is easy, keeping it frozen is another story.
08-03-2010, 12:14 PM #3
1. Proper heat calculation? no, how i can do it?
2. Figure skating
3. Just rink without seats or stands
4. What the optimal high for dome, to keep the cold in warm county ? or how i can calculate this ?
5. Insulation - what include in this operation ?
thank you very much for you help
08-03-2010, 03:10 PM #4
1) You don't. You need a properly trained professional to do it for you. It will help you avoid underestimating or overestimating the cooling capacity, and in the end will help you saving money.
2) ok
3) ok
4) Again, a proper civil engineering company will design the structure for you. They will make sure to abide to all national regulations in terms of safety for static and dinamic stresses, like seismic and similar.
5) Avoid gaining heat from the outside in summer time. Usually polyurethane is used, but it all depends on how the dome is designed and built.
09-03-2010, 05:09 AM #5
We do ice skating rinks in Australia. Allow 350watts/ square metre of ice surface. You will have sufficient capacity.
09-03-2010, 10:32 AM #6
350W/M2 may be a little low for the middle east. The last one I did in Dubai uses over 400W/M2. If it's a shopping mall rink, the load is even higher.
31-03-2010, 11:45 PM #7
02-04-2010, 12:39 PM #8
We have a rink here in Doha with 1 TRANE RTAC 250 on it 3 screw compressors on 2 systems. working -10 deg C glycol leaving control temp.
Problem only 1 chiller and no standby capabilities. Units been running 3 years and comps have accumulated over 72000hours plus between them.
1 compressor fails and we have a swimming pool. its a good unit though
aww
02-04-2010, 01:09 PM #9
03-04-2010, 10:37 AM #10
I second that, I know Charlie and have worked with him in the past. You won't find any better person for the job.
C Ice
04-04-2010, 08:50 AM #11
Thanks guy, I owe you a beer!
Axima (Germany) chillers using Turbocor compressors
By Boaz in forum New TechnologiesReplies: 4Last Post: 22-08-2011, 07:47 PM -
Those Chillers are Rubbish!
By Grizzly in forum Chit Chat & Service StoriesReplies: 24Last Post: 03-11-2009, 06:59 AM -
Question about chillers.
By sluggergrip in forum IndustrialReplies: 7Last Post: 19-11-2006, 06:30 PM
