Results 1 to 2 of 2
Thread: Heat pump design
05-03-2010, 10:40 AM #1
Heat pump design
Greetings,
First time poster, but Iīve been doing a lot of reading in the forum. Congratulations to every participant.
I am currently involved in the process of designing an air to water heat pump for domestic use.
Having determined my power needs I am currently sizing up the compressor. Here is where I need help.
For nominal conditions, 7C air to 35C water, for which temperature should I choose the compressor? Iīve been looking to software like Danfossīs RS+3 and Copeland Select7. They request evaporator and condensing temperatures superheat and subcooling as well as capacity.
Has we need a delta T to obtain nominal conditions stated before what temps should these be?
Evap. 2
Cond. 40
sc 6
sh 9
Best Regards
05-03-2010, 10:50 AM #2
Heat pump design
Oops,
Forgot to say, working with R410-A.
Heat Pump Design
By behmin in forum Heat PumpsReplies: 10Last Post: 22-03-2009, 09:00 PM -
Heat pump knocks
By Jamieheatpump in forum Trouble ShootingReplies: 9Last Post: 29-12-2008, 10:00 PM -
Air source heat pump modification
By rt29781 in forum Heat PumpsReplies: 4Last Post: 23-12-2008, 08:41 AM -
Rebuild air2air heat pump
By stalker in forum Technical SpeculationsReplies: 3Last Post: 02-11-2006, 10:10 AM
