    furyo's Avatar
    furyo Guest
    Heat pump design
    Greetings,
    First time poster, but Iīve been doing a lot of reading in the forum. Congratulations to every participant.
    I am currently involved in the process of designing an air to water heat pump for domestic use.
    Having determined my power needs I am currently sizing up the compressor. Here is where I need help.
    For nominal conditions, 7C air to 35C water, for which temperature should I choose the compressor? Iīve been looking to software like Danfossīs RS+3 and Copeland Select7. They request evaporator and condensing temperatures superheat and subcooling as well as capacity.
    Has we need a delta T to obtain nominal conditions stated before what temps should these be?
    Evap. 2
    Cond. 40
    sc 6
    sh 9
    Best Regards
    furyo's Avatar
    furyo Guest
    Heat pump design
    Oops,
    Forgot to say, working with R410-A.
  1. Heat Pump Design
    By behmin in forum Heat Pumps
    Last Post: 22-03-2009, 09:00 PM
  2. Heat pump knocks
    By Jamieheatpump in forum Trouble Shooting
    Last Post: 29-12-2008, 10:00 PM
  3. Air source heat pump modification
    By rt29781 in forum Heat Pumps
    Last Post: 23-12-2008, 08:41 AM
  4. Rebuild air2air heat pump
    By stalker in forum Technical Speculations
    Last Post: 02-11-2006, 10:10 AM
