Results 1 to 25 of 25
Thread: Hot-water circulation pump
04-03-2010, 12:50 PM #1
I'm trying to locate small hot water circulating pumps, similar to the ones shown below, but with variable speed. The ones shown below are 3-speed, fixed setting. I'd like a decent quality product.
Thanks for your suggestions. Variations on the theme will be most welcome.
04-03-2010, 01:55 PM #2
Re: Hot-water circulation pump
The three pumps I use are:
Salmson, Wilo and Pedrollo.
All good and reliable makes.
I cant tell you about prices outside my country but here the are cheap.
04-03-2010, 02:18 PM #3
Try Grundfoss they are not the cheapest but very reliable
04-03-2010, 02:30 PM #4
Thanks very much Chemi-Cool & Quality.
25-03-2010, 05:50 PM #5
normally to pump hot water , it is recomended to use a bronze cast pump, if you use a carbon steel cast pump you will get lots of black gunge in the stytem, hope this helps
25-03-2010, 06:59 PM #6
25-03-2010, 09:21 PM #7
^ That is a good tip. Thanks very much Brian.
25-03-2010, 10:18 PM #8
Slightly, or more, .
I got called to a school plantroom where they reported a copper pipe leaking.
The copper tube (1/4") was screwed, via a compression fitting, into a steel reducing bush and the main bronze pipe fitting.
It was the sensing tube for a pressure differential switch across the pump. Glad to say that I was able to valve it shut before I started because...
I put my spanner onto the steel bush and with a quarter turn it fell out of the screwed socket.
The high oxygen content of the heated domestic hot water had speeded up the electrolytic corrosion generated by the mismatch of the fittings.
I had to replace both of the fittings as the steel threads were less than half of their original length.
Also, the inside of the main pipework was 85% blocked with the by-product of the electrolytic action.
So, be warned, always check that the fittings you use match the water service.Brian - Newton Abbot, Devon, UK
25-03-2010, 10:35 PM #9
Excellents points, Brian. Thank you.
26-03-2010, 05:59 PM #10
26-03-2010, 06:58 PM #11
^^ OK, me being a pedant I suppose.
27-03-2010, 05:01 PM #12
What do you need to pump, water in a closed or open circuit?
27-03-2010, 11:59 PM #13
hi peter , in some large buildings using hight to give pressure , to giveenough hot water to each hot water tap , is not enough, so on each floor one would fit a hot water ring main to give enough hot water to each and every tap= sedgy
28-03-2010, 11:08 AM #14
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Check Grundfoss Alfa 2:
http://www.grundfos.com/web/grfosweb...grundfos+alpha
28-03-2010, 11:19 AM #15
28-03-2010, 01:05 PM #16
28-03-2010, 02:21 PM #17
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Here
Why you need variable speed?
28-03-2010, 05:17 PM #18
Thanks so much nike - you are an absolute star.
Variable speed allows a few tricks in terms of overall system efficiency.Engineering Specialist - Cuprobraze, Nocolok, CD Technology
28-03-2010, 05:56 PM #19
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
DesA, try to use proxy if you cannot access Webcaps from your location.
http://www.proxy4free.com/page1.htmlLast edited by nike123; 28-03-2010 at 06:00 PM.
28-03-2010, 05:58 PM #20
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
07-04-2010, 10:58 AM #21
Hot water circulation pumps used to be bronze but now they are stainless steel
07-04-2010, 11:25 AM #22
07-04-2010, 11:37 AM #23
07-04-2010, 07:27 PM #24
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
08-04-2010, 03:40 AM #25
Heat pump hot water system
By kiamaian in forum Technical SpeculationsReplies: 4Last Post: 16-06-2009, 06:48 AM -
Pool heat pump water side diagram
By nike123 in forum Heat PumpsReplies: 23Last Post: 22-03-2009, 07:42 PM -
Water Pump Tripping Overload. (are you sitting comfortably)?
By Grizzly in forum ElectricalReplies: 14Last Post: 27-08-2008, 08:57 PM -
heat pump water heater
By Lc_shi in forum New TechnologiesReplies: 15Last Post: 07-05-2008, 05:10 PM -
Building a wine cabinet
By Rory in forum Technical DiscussionsReplies: 38Last Post: 13-07-2004, 08:28 PM
