Results 1 to 25 of 25
    Mar 2009
    KZN, South Africa
    64
    2,212
    Hot-water circulation pump
    I'm trying to locate small hot water circulating pumps, similar to the ones shown below, but with variable speed. The ones shown below are 3-speed, fixed setting. I'd like a decent quality product.
    Thanks for your suggestions. Variations on the theme will be most welcome.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: Hot-water circulation pump
    The three pumps I use are:
    Salmson, Wilo and Pedrollo.
    All good and reliable makes.
    I cant tell you about prices outside my country but here the are cheap.
    Nov 2006
    708
    23
    Try Grundfoss they are not the cheapest but very reliable
    Mar 2009
    KZN, South Africa
    64
    2,212
    Thanks very much Chemi-Cool & Quality.
    Oct 2008
    mallorca, spain,
    75
    768
    normally to pump hot water , it is recomended to use a bronze cast pump, if you use a carbon steel cast pump you will get lots of black gunge in the stytem, hope this helps
    11,024
    Quote Originally Posted by sedgy View Post
    normally to pump hot water , it is recommended to use a bronze cast pump, if you use a carbon steel cast pump you will get lots of black gunge in the system, hope this helps
    Only if the Hot Water is for domestic use, if it is heating hot water then Bronze is not needed.
    Mar 2009
    KZN, South Africa
    64
    2,212
    ^ That is a good tip. Thanks very much Brian.
    11,024
    Slightly, or more, .
    I got called to a school plantroom where they reported a copper pipe leaking.
    The copper tube (1/4") was screwed, via a compression fitting, into a steel reducing bush and the main bronze pipe fitting.
    It was the sensing tube for a pressure differential switch across the pump. Glad to say that I was able to valve it shut before I started because...
    I put my spanner onto the steel bush and with a quarter turn it fell out of the screwed socket.
    The high oxygen content of the heated domestic hot water had speeded up the electrolytic corrosion generated by the mismatch of the fittings.
    I had to replace both of the fittings as the steel threads were less than half of their original length.
    Also, the inside of the main pipework was 85% blocked with the by-product of the electrolytic action.
    So, be warned, always check that the fittings you use match the water service.
    Mar 2009
    KZN, South Africa
    64
    2,212
    Excellents points, Brian. Thank you.
    Oct 2008
    mallorca, spain,
    75
    768
    yes thats what I said
    11,024
    ^^ OK, me being a pedant I suppose.
    Oct 2003
    5,630
    34
    What do you need to pump, water in a closed or open circuit?
    Oct 2008
    mallorca, spain,
    75
    768
    hi peter , in some large buildings using hight to give pressure , to giveenough hot water to each hot water tap , is not enough, so on each floor one would fit a hot water ring main to give enough hot water to each and every tap= sedgy
    Split Croatia
    57
    6,151
    36
    Quote Originally Posted by desA View Post
    Check Grundfoss Alfa 2:
    http://www.grundfos.com/web/grfosweb...grundfos+alpha
    Mar 2009
    KZN, South Africa
    64
    2,212
    Hi Peter,
    In my case it would be for hot water in a closed loop.
    Mar 2009
    KZN, South Africa
    64
    2,212
    Would it be possible to post the Alpha data sheets to a download site, as I cannot access them off WebCAPS, where I am at present.
    This would be incredibly helpful.
    Split Croatia
    57
    6,151
    36
    Here
    Why you need variable speed?
    Mar 2009
    KZN, South Africa
    64
    2,212
    Thanks so much nike - you are an absolute star.
    Variable speed allows a few tricks in terms of overall system efficiency.
  19. #19
    Split Croatia
    57
    6,151
    36
    DesA, try to use proxy if you cannot access Webcaps from your location.
    http://www.proxy4free.com/page1.html
  20. #20
    Split Croatia
    57
    6,151
    36
    If you need constant differential pressure, that is easy to achieve with overflow valve.
  21. #21
    Endex's Avatar
    Endex Guest
    Hot water circulation pumps used to be bronze but now they are stainless steel
  22. #22
    Mar 2009
    KZN, South Africa
    64
    2,212
    Quote Originally Posted by Endex View Post
    For chlorinated water?
  23. #23
    Mar 2009
    KZN, South Africa
    64
    2,212
    Thanks nike.
    Could you perhaps go into more detail on this?
  24. #24
    Split Croatia
    57
    6,151
    36
    Check this PDF!
    And this!
  25. #25
    Mar 2009
    KZN, South Africa
    64
    2,212
    Check this PDF!
    And this!
    Thanks so much, nike. Very nice & simple.
    I wonder if the pump thermal input would gradually raise the circulating water temp, over time?
  1. Heat pump hot water system
    By kiamaian in forum Technical Speculations
    Last Post: 16-06-2009, 06:48 AM
  2. Pool heat pump water side diagram
    By nike123 in forum Heat Pumps
    Last Post: 22-03-2009, 07:42 PM
  3. Replies: 14
    Last Post: 27-08-2008, 08:57 PM
  4. heat pump water heater
    Last Post: 07-05-2008, 05:10 PM
  5. Building a wine cabinet
