Results 1 to 14 of 14
Thread: return air , please help me,!!!
01-03-2010, 01:21 AM #1
Hi, friends !!!
i have an room which just need 18000 btu/h !!!
But i use 21000 btu/h .
Now i have problem , the temp is alway lower than the set temp !!! (ex: i set temp at 23 the room temp will be 21 ) so,can i fix this problem ???
Thank , a lot my friends !!!
Thank forum and best development !!!
01-03-2010, 01:36 AM #2
Re: return air , please help me,!!!
Set 25 ;-)
If it is an inverter then most units will go to lowest running power, for one degree past set point, before switching off. Best option is to set a slightly higher temp.
01-03-2010, 01:37 AM #3
Hi your rating of your AC is just a number at one point, you may be getting more or less depending on many factors.
I would say just turn up thermostat by 2C (it may just be a calibration issue) When testing control temps you must have thermometer in the same place as AC thermostat sensor.
If AC is way to big, you tend to find the the room will have very high RH.
01-03-2010, 01:48 AM #4
Also, set the fan to its lowest speed.
02-03-2010, 12:52 AM #5
thank friend !!!
the sensor of remote and return air is the same at the temp set in remote . but the temp of room is lower than 1.5 to 2 deg !!!
Thank friends
thank forum and best regard !!!
02-03-2010, 07:47 PM #6
If the return air is warmer than the room it is because the return has picked up the load from the room.
More details as to the type, location and airflow around, from and back to the unit would be useful.Brian - Newton Abbot, Devon, UK
10-03-2010, 07:26 AM #7
Hi, friends !!!
After have a full tracking with my VRV3 system i have some parameter :
-The set temp = 23 deg (the temp want to set for the room)
- the return air temp = 23 deg
- the remote sensor temp = 23 deg
- The temp of room = 21.5 deg ????
What were happen ?
our group had tried our best to fix this problem ....
ex :- setting to use only remote sensor
-change remote position
-check all the sensor
but it seem not have any effective .
Could you hep me , my friends?
Thank you a lot .
Thank our forum .
Best Kind !!!
10-03-2010, 06:48 PM #8
Whereabouts is the remote controller in relation to where you are measuring the room temperature?
What happens to the room temperature when to increase the control temperature by 2 degrees?Brian - Newton Abbot, Devon, UK
11-03-2010, 02:07 AM #9
hi, friend !!!
Have a nice day (^_^)
thank you for your advice
when i set the time of room = 24 deg
The remote sensor temp = 24
the return air sensor = 24
And the temp of room is maintain at 22-22.5
Thank you a lot !!!
thank forum
Best kind and best regard
13-03-2010, 12:51 AM #10
oh, friends !!!
Why you do not help me ?
I am tire so much for that problem
who can give me an advice ???
Thank you alot
thank forum !!!
Best regard !!!
13-03-2010, 01:06 AM #11
13-03-2010, 03:34 PM #12
The unit is over sized. Not only temperature will go down humidity also will increase. Best thing is to change the air quantity to suit your requirement then the thermostat can take over to modulate within a range.
13-03-2010, 04:17 PM #13
- Join Date
- Sep 2007
- Location
- Split Croatia
- Age
- 57
- Posts
- 6,151
- Blog Entries
- 6
- Rep Power
- 36
With what instrument you are measuring that temperatures? Is it calibrated?
Or you are giving us temperatures of unit thermistors read from remote control and actual room temperature read from some measuring instrument.
It looks to me that your measuring instrument is off by 1.5°CLast edited by nike123; 13-03-2010 at 04:39 PM.
15-03-2010, 12:26 AM #14
Turn the fan speed down to the LOWEST you can select. This will mean less air circulation so less output from the unit.
particulary useful if the unit is oversized.
daikin return air problem
By Kev The Tool in forum Air ConditioningReplies: 7Last Post: 17-02-2010, 03:50 PM -
McQuay ALS F XE273.2 990Kw, highest return temp?
By THE WOMBAT in forum Technical SpeculationsReplies: 1Last Post: 07-08-2009, 10:59 AM -
Best place for return air sensors, in the room or ceiling void?
By back2space in forum Air ConditioningReplies: 27Last Post: 06-07-2009, 06:21 AM -
R404a Oil Return
By dallan in forum IndustrialReplies: 1Last Post: 23-08-2004, 12:40 AM -
return air
By subzero*psia in forum Air ConditioningReplies: 1Last Post: 12-07-2001, 04:02 PM
