    joseloyd's Avatar
    joseloyd Guest
    parallel operation of compressor
    is it a good practice or not to operate two compressor in parallel?
    May 2009
    Sydney
    73
    Re: parallel operation of compressor
    Carrier chillers do it all the time, up to 5 or 6 compressors / circuit.
    Jan 2009
    Athnes Greece
    43
    9
    parallel compressor achieve better control of the ref load and they consume less electricity than a big one. Oil by pass should exist in every compressor and something to control the amount of oil in each compressor
    joseloyd's Avatar
    joseloyd Guest
    on board the ship, we have two sets of compressor & every compressor has a condenser. When we are in tropical areas, we used two compressor in parallel to coolin' it up, is there any disadvantage with this operation?
    Sep 2003
    ISRAEL
    72
    4,248
    Many units have two compressors in parallel.
    On cooling units for Laser cutting machines its very common, when temp is close to set point, one of them is going out and coming in when load increase.
    The controller is also controlling the working time of each one so they run equally.
    The sumps are connected with a ball valve in between for easy replacing.
    joseloyd's Avatar
    joseloyd Guest
    ok thanks for the info.
  1. MP66 & Compressor Overheating
    By Intermez in forum Technical Discussions
    Last Post: 13-04-2010, 08:58 PM
  2. hot idle compressor on parallel rack system
    By friocold2008 in forum Supermarket Refrigeration
    Last Post: 05-12-2009, 08:37 AM
  3. Replies: 3
    Last Post: 29-10-2009, 09:41 PM
  4. SL/SB-400 Pump Down Procedures
    By absolute-zero in forum Transport
    Last Post: 29-01-2008, 09:27 PM
  5. Compressor Capacity
    By engrkate in forum Fundamentals
    Last Post: 13-10-2006, 12:11 AM
