Thread: Drain Water in ductless system
25-02-2010, 03:41 PM #1
Help!!!!!!
Any team member khow the best way to remove drain water from ductless system without breaking the wall. I plan to install a ductless system in the American Housing-Residdential. Thanks
25-02-2010, 06:50 PM #2
Re: Drain Water in ductless system
Don't quite understand the term 'ductless' but if there is refrigerant pipework from indoor to outdoor, where is that going?
25-02-2010, 08:33 PM #3
A ductless A/C system is a sytem does not need the duct to deliver the cool air to cool any space. In another words, A ductless flows cool air directly to the space with out using any insulated duct/ tunnel / vent.
25-02-2010, 09:11 PM #4
Ductless is the US term for a wall mount (usually) as Brian Say's where are the fridge pipes going?
Oh and I like the fact that this is in the 'new technologies' sectionLast edited by multisync; 25-02-2010 at 09:19 PM.
25-02-2010, 09:21 PM #5
Refrigerant pipe will be in the annex and run down to the blower in wall mount unit.
25-02-2010, 09:38 PM #6
from your details , you add a pipe for drain water, to fallow the refrigeration pipe's
25-02-2010, 10:50 PM #7
OK, your refrigerant pipes will come down the wall from above the unit without penetrating any walls.
Install a mini-condensate pump which will fit inside the wall unit and run the small bore plastic drain pipe up behind the refrigerant pipes. Follow the pipework back outside to the outdoor unit.Brian - Newton Abbot, Devon, UK
chart for PVC pipes closed chilled water system
By mackistired in forum Air ConditioningReplies: 4Last Post: 14-11-2009, 03:23 AM -
Water in NH3 refrigeration systems
By JCollins in forum FundamentalsReplies: 13Last Post: 05-11-2009, 02:35 PM -
Water circuit on chiller system
By DL A/C in forum Technical SpeculationsReplies: 3Last Post: 21-10-2009, 01:42 AM -
pure water from air
By Lc_shi in forum New TechnologiesReplies: 32Last Post: 26-02-2009, 12:25 PM -
Energy saving in Chilled water system
By psrao in forum Tools and CalculatorsReplies: 5Last Post: 15-01-2008, 06:54 PM
