    Jan 2010
    usa
    14
    Drain Water in ductless system
    Help!!!!!!
    Any team member khow the best way to remove drain water from ductless system without breaking the wall. I plan to install a ductless system in the American Housing-Residdential. Thanks
    11,025
    Re: Drain Water in ductless system
    Don't quite understand the term 'ductless' but if there is refrigerant pipework from indoor to outdoor, where is that going?
    Jan 2010
    usa
    14
    A ductless A/C system is a sytem does not need the duct to deliver the cool air to cool any space. In another words, A ductless flows cool air directly to the space with out using any insulated duct/ tunnel / vent.
    Jul 2008
    London
    848
    Ductless is the US term for a wall mount (usually) as Brian Say's where are the fridge pipes going?
    Oh and I like the fact that this is in the 'new technologies' section
    Jan 2010
    usa
    14
    Refrigerant pipe will be in the annex and run down to the blower in wall mount unit.
    Jun 2005
    Romania
    213
    from your details , you add a pipe for drain water, to fallow the refrigeration pipe's
    11,025
    OK, your refrigerant pipes will come down the wall from above the unit without penetrating any walls.
    Install a mini-condensate pump which will fit inside the wall unit and run the small bore plastic drain pipe up behind the refrigerant pipes. Follow the pipework back outside to the outdoor unit.
  1. chart for PVC pipes closed chilled water system
    By mackistired in forum Air Conditioning
    Last Post: 14-11-2009, 03:23 AM
  2. Water in NH3 refrigeration systems
    By JCollins in forum Fundamentals
    Last Post: 05-11-2009, 02:35 PM
  3. Water circuit on chiller system
    By DL A/C in forum Technical Speculations
    Last Post: 21-10-2009, 01:42 AM
  4. pure water from air
    Last Post: 26-02-2009, 12:25 PM
  5. Energy saving in Chilled water system
    By psrao in forum Tools and Calculators
    Last Post: 15-01-2008, 06:54 PM
