25-02-2010, 11:33 AM #1
proper distribution inside plate evaporators?
Hi friends
I want to assemble an(plate heat exchanger) ecomomizer and attach it to screw compressor at -15eva. and +35con.by R22.
how can I be so sure about proper distribution of liquid injection or expansion in evaporator side(plates) of economizer concerning to so many plats? is it neccessary to use of especial part or not?
Thank u in advance for advice.
S.P
25-02-2010, 11:36 AM #2
Re: proper distribution inside plate evaporators?
Maybe Tichelman principle can be applied here.
25-02-2010, 12:37 PM #3
For a small brazed unit used as economizer, distribution is pretty much self regulating. For larger PHE evaporators, a distribution tube is mounted inside the (lower) liquid connection to ensure liquid is injected into every passage.
25-02-2010, 12:39 PM #4
thank
but I think Thichelman priciple usually define in uniform pipe&flow and single-phase liquid inside.not here.S.P
25-02-2010, 12:47 PM #5
I have seen injection tube used on large PHE however I gon"t know how to calculate hole sizes. I think this would be fairly critical.
25-02-2010, 07:19 PM #6
Try the SWEP site they have downloadable application software and manuals
http://www.swep.net/index.php?tpl=page0&lang=en&id=113Reality is an elusion created by alcohol deficiency. Quaff and enjoy. [Yorkshire, UK]
25-02-2010, 07:29 PM #7
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
Check this manual page 97.
However, dimensions are not given but you could call Alfa Laval technical support and ask if they have ready made products.
26-02-2010, 03:08 PM #8
26-02-2010, 03:45 PM #9
- Sep 2007
- Split Croatia
- 57
- 6,151
- 6
- 36
