Thread: b&q split playing up.
25-02-2010, 10:05 AM #1
hey lads having problems with an b & q airforce unit
yep there cheap but its a friend of a friend job.
any1 know where i can get technical info from i.e. fault codes, wiring diagrams
asked bnq but they sent me on a wild goose chase.
cheers for the helpo lads much appreciated
25-02-2010, 10:36 AM #2
Re: b&q split playing up.
I think they are made by Gree air conditioning dont know of anyone providing tech support in UK.
25-02-2010, 04:39 PM #3
how do you polish a te!d ,they are junk chuck it out
02-03-2010, 07:36 PM #4
I'd use Kiwi Dark Tan.
02-03-2010, 10:37 PM #5
your better of starting again with a new 1!!
05-03-2010, 08:37 PM #6
no idea where you can get any inf, but iwould start with a full recovery pressure test evac and recharge. the 3 that i've worked on needed that. good luck.
3 single split units or one multi split - consumer advice needed
By kok in forum Air ConditioningReplies: 18Last Post: 15-04-2009, 08:42 PM -
Sensible Heat Factor / capacity of Inverter split Systems at part load?
By Greengrocer in forum Technical SpeculationsReplies: 31Last Post: 09-02-2009, 04:57 PM -
Australian split installers, some info needed
By paul_h in forum Air ConditioningReplies: 10Last Post: 20-05-2008, 03:40 PM -
Do you beleive in data of split units?
By jirhol in forum FundamentalsReplies: 4Last Post: 29-03-2008, 11:17 PM -
High overcurrent on 3.5kW heatpump split
By Makeit go Right in forum Air ConditioningReplies: 12Last Post: 08-03-2007, 12:27 AM
