Thread: calculation errors
10-02-2005, 05:09 PM #1
calculation errors
Hay
The primary data;
Fast freezer for mushrooms
500kg/6h in cartoon boxees 600 x 500 x300mm
T initial=4*C T final =-30*C
Enviroment temp 32*C constant
Insulation polyurethane thickness=120mm
I use 3 diferent programs for this calculation & i got 3 different
results 1 Q=15.10kw /-35*C
2 Q=18.59Kw/-35*C
3 Q=13,9Kw/-35*C
How about it ?
10-02-2005, 05:23 PM #2
Re: calculation errors
How did you calculate it?
Chemi
11-02-2005, 06:01 AM #3
Simple,I put the same data in all 3 programes.Why you ask ? .The result are not good ?.
11-02-2005, 01:14 PM #4
The differance is too big.
What programs did you use and what is the size of the room?
Chemi
11-02-2005, 01:53 PM #5
Room size
Lenght=3m
weight=2m
height =3m
result 1 cooltool (demo version)
result 2 coldroom
result 3 Scelte
coldroom calculation freeware
By coldcraft in forum Tools and CalculatorsReplies: 10Last Post: 17-01-2009, 02:31 PM -
Heat Load calculation for residential jobs
By Herschmidt in forum Air ConditioningReplies: 2Last Post: 12-05-2008, 11:50 PM -
Calculation to determine run capacitor size
By sturrup in forum The Trail of TearsReplies: 0Last Post: 02-11-2002, 06:25 PM -
Heat load calculation
By Tony in forum Technical DiscussionsReplies: 3Last Post: 29-07-2002, 06:34 PM
