Results 1 to 2 of 2
    Dec 2005
    SCOTLAND
    47
    Hallscrew HS L/M 3100 Series
    Has anyone got any experiance on this particular comp.
    HAving high oil level (opto sensor) problems on plant shut down. Could be problem with opto sensor or internal drain/nrv which drains oil from suction to discharge on shut down. Its not the oil return sol valve from the oil sep (Parker s4a) as new valve kit fitted at weekend. Any help appreciated
    Thanks Jason
    Dec 2005
    SCOTLAND
    47
    Re: Hallscrew HS L/M 3100 Series
    OK....All is good...the opto sensor was defective, replaced and now all ok!
  1. Sullair C Series and CB Series
    By Oz Fridgey in forum Industrial Compressors
    Last Post: 18-02-2009, 09:44 PM
  2. New to RE and needing Daikin Help
    By Owen in forum Air Conditioning
    Last Post: 25-09-2008, 06:55 PM
  3. Defrost Elements in series?
    By Drew in forum Electrical
    Last Post: 26-06-2008, 07:28 AM
  4. 2 chillers in series
    By giovanni in forum Technical Discussions
    Last Post: 23-06-2007, 07:08 AM
  5. VRV fault
    By Jase in forum Air Conditioning
    Last Post: 16-05-2007, 08:21 PM
