Thread: Hallscrew HS L/M 3100 Series
22-02-2010, 02:02 PM #1
Has anyone got any experiance on this particular comp.
HAving high oil level (opto sensor) problems on plant shut down. Could be problem with opto sensor or internal drain/nrv which drains oil from suction to discharge on shut down. Its not the oil return sol valve from the oil sep (Parker s4a) as new valve kit fitted at weekend. Any help appreciated
Thanks Jason
16-03-2010, 09:34 AM #2
Re: Hallscrew HS L/M 3100 Series
OK....All is good...the opto sensor was defective, replaced and now all ok!
Sullair C Series and CB Series
By Oz Fridgey in forum Industrial CompressorsReplies: 3Last Post: 18-02-2009, 09:44 PM -
New to RE and needing Daikin Help
By Owen in forum Air ConditioningReplies: 20Last Post: 25-09-2008, 06:55 PM -
Defrost Elements in series?
By Drew in forum ElectricalReplies: 8Last Post: 26-06-2008, 07:28 AM -
2 chillers in series
By giovanni in forum Technical DiscussionsReplies: 18Last Post: 23-06-2007, 07:08 AM -
VRV fault
By Jase in forum Air ConditioningReplies: 10Last Post: 16-05-2007, 08:21 PM
