    Jan 2005
    saudi arabia
    44
    estimated life of a solenoid coil ?
    Hi guys;
    Do u know what is the estimated life of a solenoid coil ? I am asking this information for stocking reason.
    Sep 2003
    ISRAEL
    72
    4,248
    Re: estimated life of a solenoid coil ?
    From my experience only, (there may be other opinions) Alco, the best. Danfoss, I have change a few over the years but not many. Parker and Sporlan gave me more income.
    Castel is the worth, I keep at all times, 3 or 4 coils.
    You have to know that coils work with different voltages, 240, 110, 24 and 24DC.
    Most common are those working at 240 ACV. you can use 240coil on instead of a 24ACV but you can not use an AC coil instead of DC coil.
    If I remember correct, the hole is of different diameter.
    Chemi
    Jan 2005
    saudi arabia
    44
    Quote Originally Posted by chemi-cool
    Thanks Chemi. I wantta know what did u mean by the quote above ? do u mean it has to be changed frequently ?
    Jun 2002
    628
    23
    Hi eng_ab,welcome to RE
    The estimated life of a solenoid coil depends on field conditions,temperature,humidity etc. And in what application it is applied
    Me i like using danfoss. Other makes have a higher failure rate in my opinion of course .
    Regards.Mark
    Sep 2003
    ISRAEL
    72
    4,248
    Hi eng_ab,
    I mean that I change them more often then Danfoss - I make more money.
    But as Mark says, Field conditions will have their effect on the coil's life.
    Chemi
    Jan 2005
    saudi arabia
    44
    What about Hansen's coils ? I was really surprised about Parker and Sporlan's coil performance i thought there r the best manufacturers in this industry.
    Eng. AB
  1. Indoor coil capacity?
    By Larry2 in forum Air Conditioning
    Last Post: 23-07-2006, 01:47 AM
  2. DX coil distributor issue
    Last Post: 16-11-2005, 01:03 PM
  3. solenoid coil
    By piston broke in forum Electrical
    Last Post: 14-08-2005, 05:03 AM
  4. Burst Coil
    By frank in forum Air Conditioning
    Last Post: 20-02-2005, 06:28 PM
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
