20-02-2010, 08:32 PM #1
Problem about Inverter and Compressor
Inverter can suitable for all model of compressor (Example: Scroll , Screw or semi-hermetic compressor) ? Or just can use on some special compressor have variable speed function ?
21-02-2010, 10:23 AM #2
Re: Problem about Inverter and Compressor
Positive displacement compressors (all those that you mentioned) should be connected to constant torque frequency converter only, e.g.: not HVAC inverters for pumps and fans.
21-02-2010, 01:31 PM #3
21-02-2010, 03:01 PM #4
I can't write it else way. It's self explanatory.
daikin L0 inverter problem
By robin r33 gtr in forum Air ConditioningReplies: 17Last Post: 11-03-2010, 11:25 PM -
Daikin Inverter Board / Compressor issues
By Greengrocer in forum Air ConditioningReplies: 12Last Post: 21-04-2009, 10:12 PM -
Sharp inverter problem
By marc5180 in forum Air ConditioningReplies: 6Last Post: 17-06-2008, 05:28 PM -
Problem with an inverter compressor in V.R.V system DAIKIN R 407
By Harris Greece in forum Air ConditioningReplies: 10Last Post: 24-11-2007, 12:53 AM -
noise inverter compressor
By Airclima in forum Air ConditioningReplies: 1Last Post: 26-07-2007, 11:42 PM
