    alexilla's Avatar
    alexilla Guest
    Oil volume in custom refrig circuit
    Hello. I am new to the refrigeration industry. On a custom built refrigeration circuit, are there any tools or formulas to use in calculating the proper volume of compressor oil to use? Or is there a rule of thumb? Any help would be greatly appreciated!
    May 2009
    Sydney
    73
    Re: Oil volume in custom refrig circuit
    alexilla
    The oil is for the compressor, not for the refrigeration circuit or any other component. Correct pipe sizing is the primary concern with any refrigeration system to ensure proper oil return.
    alexilla's Avatar
    alexilla Guest
    So, what your saying is that the volume of compressor oil contained within a refrigeration circuit is strictly proportional to the size/type of compressor(s) used?
    May 2009
    Sydney
    73
    Exactly right. If the system piping is correct oil return will not be a problem. However there are exceptions to the rule as in flooded and ammonia systems. Also you should never add oil to a system unless you know where the existing oil has gone.
    alexilla's Avatar
    alexilla Guest
    Thats exactly what I wanted to know. Thank you for your help
    May 2009
    Sydney
    73
    Glad to be of assistance.
  1. problem with volume on frick screw compressor
    By samlee12 in forum Industrial
    Last Post: 29-10-2009, 06:06 AM
  2. problem with frick screw volume
    By samlee12 in forum Industrial Compressors
    Last Post: 20-06-2009, 02:46 PM
  3. Calculation bypass buffer tank volume
    By abbasi in forum New Technologies
    Last Post: 16-10-2008, 06:19 AM
  4. Replies: 16
    Last Post: 09-03-2006, 12:39 PM
  5. How critical are circut lengths when using a distributor?
    By kengineering in forum Technical Discussions
    Last Post: 27-02-2006, 07:35 AM
