Thread: Refrigeration for Fishing Ships
19-02-2010, 03:34 AM #1
Hi everyone,
Does anyone have any guidelines for refrigeration systems for fishing ships? I need to design one that has a brine freezer and a couple of storage rooms, but I am not sure about the considerations needed for this.
Appreciate all your help!
Lawrence
19-02-2010, 06:33 AM #2
Re: Refrigeration for Fishing Ships
Hi Lawrence, have a look at this
http://www.matsu.alaska.edu/document...oat_Refrig.pdf
TooshMy wife used to say you never listen to a word I say at least I think that what she said
24-02-2010, 06:03 AM #3
Hi Toosh,
Thanks for the reply. Although I need to find actual design procedures for to calculate for the components required.
Appreciate the help!
Lawrence
25-02-2010, 09:59 AM #4
Specify design parameters .
You will need
a) see water cooled condenser
b) compressor which can be used on marine application , due consideration for constant rolling-pitching action
c) electrical system which is suitable for marine weather
d) refrigeration piping should be preferably elect welded / gas welded ; avoid threaded joints .
E) water cooled condenser to be with cupro-nickel (70:30)
f) paint : Marine grade
details can be worked out after load conditions are finalized .
Give further details .
25-02-2010, 12:39 PM #5
BIG suction traps.
advanced refrigeration technology
By Lc_shi in forum FundamentalsReplies: 10Last Post: 16-02-2011, 05:22 PM
