    Jun 2009
    United States
    45
    34
    Frick rwb ii coalescers
    I just changed my first coalescers last week. Not as bad as I was told it would be. Just had a heck of a time trying to get the manway gasket to line up all the way around the manway cover. I used a little bit of tape to hold it on while I tightened it up. Is there a easier way to do this like use a adhesive to hold the gasket in place?
    Jul 2006
    74
    865
    26
    Re: Frick rwb ii coalescers
    Using a contact adhesive works well for me. This is recommended by FES on their machines.
    To continue a bit, I like to make my own out of Neoprene when possible. 50-60 Durometer works well. For ***** machines virgin Neoprene is recommended.
    I like 1/8" material. Thicker is not better. A thick gasket can, and will blow out.
    Another note: before you start to depressurize a compressor to change the coalescer, always tighten the manway cover. If you do not it may start to leak as the pressure drops.
    (I learned these things the hard way)
    Jul 2008
    wet coast B. C.
    122
    NH3s On a similar note, I use STP for holding O rings in place when changing disposable oil filters. C.D.
    NH3 for me
    Jun 2009
    United States
    45
    34
    Yeah, some guys showed me they like nickel plate anti seize, or armite led plate 250
  1. problem with volume on frick screw compressor
    By samlee12 in forum Industrial
    Last Post: 29-10-2009, 06:06 AM
  2. Big Frick was locked up
    By bruceboldy in forum Industrial Compressors
    Last Post: 08-08-2009, 03:45 PM
  3. problem with frick screw volume
    By samlee12 in forum Industrial Compressors
    Last Post: 20-06-2009, 02:46 PM
  4. Frick compressor RXF 101-H
    By PaulZ in forum Industrial Compressors
    Last Post: 19-02-2009, 02:29 AM
  5. Replies: 12
    Last Post: 16-06-2008, 10:06 AM
