Results 1 to 15 of 15
    Jan 2005
    saudi arabia
    44
    What kinf of pipes are used for coldstores ?
    Hi guys;
    Please can u tell me what kind of pipes r commonly used in coldstores ? and what standard sizes r used ?
    Sep 2003
    ISRAEL
    72
    4,248
    Re: What kinf of pipes are used for coldstores ?
    Pipes for what in a cold store, water?, refrigerants?
    Be more specific, please.
    Chemi
    May 2004
    southern england
    69
    86
    round ones
    it's only a fridge, fix it. ;)
    Oct 2003
    5,630
    34
    We mostly uses spiral duct for R404a and flexible duct (isolated of course) for R134a.
    Till 2 kW you need a duct of 5 inch, from then 8 inch.
    If used for freezer application, isolate the duct very good.
    A good tip, you can use the inner side of the duct as a cable tray, fits all inside it and it's good looking.
    Use a good quality duct-tape, especially with R404a because that gas becomes real cold.
    11,025
    Quote Originally Posted by Peter_1
    ...snip...Use a good quality duct-tape, especially with R404a because that gas becomes real cold.
    LOL Peter, you test my rib cage
    Oct 2004
    Australia
    64
    41
    generally copper exept for R717 with is steel. Either hard or soft drawn depending on size and application. Soft usually only availible up to 7/8". although over 5/8" is a pain to work.The pipe must be ref. grade which is clean, dehydrated and always capped both ends Standard sizes 1/8", 3/16",1/4",3/8",1/2",5/8",some 3/4",7/8",1 1/8", 1 3/8", 1 5/8".These are most commen, there is of course bigger but im not very familar with these, one of the industrial techs or larger A/C boys will know these I havent done multi storey work since 1989 Dont be put of by the sarcasam of others, bit of a fridgey trait.
    Jan 2005
    saudi arabia
    44
    Appreciate ur help guys, especially coolkev. What about pipes used for ammonia and R22 ? Do u know good pipe manufacturers ? What good certificates are generally achieved to make the manufactured pipe approved from most coldstores ?
    rbartlett's Avatar
    rbartlett Guest
    ammonia will be steel
    R22 is copper only
    standards for refrigerant quailty pipe are
    ASTM B 280 and EN 12735-1
    http://www.metalagencies.com/copper_alloy_tubes.htm
    best bet is to employ us as consultants to oversee the project.
    cheers
    richard
    Jan 2005
    saudi arabia
    44
    Thanx 4 ur help rbartlett.
    Do u work in metalagencies or u do consulting individually ?
    rbartlett's Avatar
    rbartlett Guest
    check our website
    http://www.fridgetech.com
    cheers
    richard
    Jan 2005
    saudi arabia
    44
    richard, did fridgetech handled some projects in the middle east ?
    I am impressed by ur customers. Especially the cafebar, that was neat. Where is the location of this cafebar ? Maybe one day i can visit it .
    rbartlett's Avatar
    rbartlett Guest
    As yet we haven't handled any middle east projects as Fridgetech (although personally I have in my previous company in Saudi btw.)
    However fridgetech has had experience in Nigeria for Mobil and Daewoo
    Check the bottom of this page...
    http://fridgetech.com/subcontracting/
    The cafe bar was a project in hinckley ;-)
    http://www.hinckley-online.co.uk/about_h.shtml
    Richard
    Jan 2005
    saudi arabia
    44
    Cool where did u work at saudi arabia ?
    Jan 2005
    saudi arabia
    44
    When speaking of steel pipe used for R717. Do u refer to carbon steel or something different ?
    rbartlett's Avatar
    rbartlett Guest
    Quote Originally Posted by eng_ab
    On the Prince Sultan Air Base
    Al-Kharj
    cheers
    richard
  1. frost on compressor pipes
    By gabyz in forum Domestic
    Last Post: 17-05-2006, 05:09 AM
  2. cooling copper pipes after braizing
    By rbartlett in forum Fundamentals
    Last Post: 11-09-2004, 09:03 AM
