Results 1 to 21 of 21
Thread: Unistrut
16-02-2010, 01:45 PM #1
Unistrut
I need to mount a condenser on a non gable end out over the gutter to stop chavs stealing or damaging it.Unfortunately the eves and gutter stick out far enough that the condenser wont fit unless the cantilever arm is 900mm long. The units are on the small size and weigh around 40kg. Unistrut only do a 720mm long arm, is there anyway to extend this with an extension and is it safe?
16-02-2010, 03:15 PM #2
Re: Unistrut
You can get some L brackets and make your own cantilever to the length that you need, you could also reinforce it by fixing a piece of channel cut at 45 degrees, with a bracket bolted top and bottom.
If you ask your supplier for a Unistrut catalogue it will all make sense.
CheersTutto il Mondo e un Paese
16-02-2010, 04:07 PM #3
Re: Unistrut
Yes i have had a look at the catalogue, the angle brackets dont seem safe in that it could pull out of the horizontal bar easily. I am thinking of a 750mm cantilever arm and a unistrut coupler perhaps reinforced with the angle as you say from underneath? This is probably safer as the back of the compressor at least will rest on the solid part of the cantilevered arm.
16-02-2010, 04:07 PM #4
Re: Unistrut
What is the best place to get the unistrut components needed in Dublin. Cheers
16-02-2010, 06:34 PM #5
Re: Unistrut
I'm sure our local ducting company sell 900mm unistrut style brackets, might be worth trying some different companies.
16-02-2010, 06:44 PM #6
16-02-2010, 07:22 PM #7
16-02-2010, 08:41 PM #8
Re: Unistrut
why not just get a bracket made up urself. have seen many of these usaly for holding fridge condensers
16-02-2010, 09:09 PM #9
Re: Unistrut
Lomb
RDL and Fridge spares do a 900 arm
alec
16-02-2010, 10:11 PM #10
Re: Unistrut
Why not just use the cantilever brackets you have available, cut some unistrut to required length and bolt them to the original brackets?
Andy
16-02-2010, 11:07 PM #11
Re: Unistrut
If only it was that simple! Forces and Moments calculations is what you need to check.
Does this look safe?
16-02-2010, 11:48 PM #12
16-02-2010, 11:49 PM #13
16-02-2010, 11:51 PM #14
17-02-2010, 01:41 PM #15
Re: Unistrut
Hilti do a 1000mm arm
Eggs
17-02-2010, 08:50 PM #16
Re: Unistrut
Use bolts and zebedees to hold the strut to the bracket, you don't need joiners.
Andy
25-02-2010, 05:31 PM #17
Re: Unistrut
2 thoughts... you can get double width cantilever arms ie reinforced on the bottom so it is essentially 2 arms in one.
Also if you fix unistrut vertically up the wall as opposed to simply anchoringthrough the eyes in the bracket you will get more fixings.
25-02-2010, 06:37 PM #18
25-02-2010, 07:01 PM #19
Re: Unistrut
If you zoom in on that picture, you can see that the suction pipe suddenly reduces just before it connects onto the service valve
Looks like 1+1/8 down to 3/4 or 5/8
25-02-2010, 08:12 PM #20
25-02-2010, 11:12 PM #21
What is the best way to mount a split to a wall?
By paul_h in forum Air ConditioningReplies: 18Last Post: 28-09-2008, 03:57 PM -
Cutting unistrut
By Andy AC in forum Tools and CalculatorsReplies: 9Last Post: 27-05-2007, 09:32 PM
