Thread: Sabroe SMC 106
    Jun 2009
    Canada
    55
    82
    15
    Sabroe SMC 106
    Hi guys
    I had a call from a customer who wanted a fitting to convert the hand oil pump connection to a pipe thread. They thought the existing connection was 24 mm female but I think it's more like 30 or 32 mm female, does anyone know right off hand what it is. I can't get to there to check it.
    C Ice
    Nov 2004
    China
    176
    Re: Sabroe SMC 106
    The connection in the crankcase is female G-3/4" The easiest conversion piece can usually be found at Williams Fluidair in Pickering. http://www.williamsfluidair.com/
    Auckland
    74
    3,357
    37
    Re: Sabroe SMC 106
    3/4 inch BSPP
    Jul 2007
    Czech
    61
    374
    Re: Sabroe SMC 106
    Mk 1+2 G3/4in,Mk 3+4 G 1/2 in.
    Attached Files Attached Files
  1. Sabroe Co2 compressor
    By Sturt in forum Old Refrigeration Photos
    Last Post: 19-02-2010, 03:29 PM
  2. sabroe plate freezer
    By samlee12 in forum Industrial
    Last Post: 25-11-2009, 11:48 PM
  3. Sabroe compressor
    By ibraheem in forum Technical Speculations
    Last Post: 12-07-2009, 02:07 PM
  4. Vibration Dampers on Sabroe Compressors
    By kelvin_27_84 in forum Industrial Compressors
    Last Post: 11-05-2008, 05:55 PM
  5. sabroe water chiller
    By dill in forum Air Conditioning
    Last Post: 17-12-2006, 07:26 PM
