Results 1 to 12 of 12
15-02-2010, 04:21 PM #1
How are the Daikin Altherma units?
Any input on the quality and reliability of the Altherma units would be appreciated.
I am in the US and the Altherma air to water units will be available to me shortly. I have been installing Mitsubishi units for 20+ years and Fujitsu for 5 and they have been extremely reliable. But I have no experience with Daikin equipment.
I have several applications for the Altherma units. Here in NY we have had quite a few -15 C days this January.
I would like to know how these units are working out for you guys in GB as they have been available to you for several years.
The Mitsubishi air to water units are not yet available to me yet.
thanks
15-02-2010, 04:41 PM #2
Re: How are the Daikin Altherma units?
Hello LucMan and welcome to the forum.
If you use the 'Search' function above you will find quite a few threads about the Altherma which just might give you some insight.
If you experience low temps around -15(C or F?) then I would definately fit the additional Baseplate heater.
15-02-2010, 06:27 PM #3
15-02-2010, 07:28 PM #4
15-02-2010, 07:32 PM #5
16-02-2010, 12:24 AM #6
It seems that the Europeans get all the new equipment before we do. No air to water heat pumps (for space heating) available to us at this time, to be released shortly in the US. Daikin will be the first.
The reason that I am interested in these units is because there are quite a few solar PV systems installed and clients are interested in electric space heating. Lots of interest in Heat pumps as our electric rates have been stable not so with oil or gas. As our winter temps can be quite cold the only options have been Geo thermal with ground loops or vertical wells. Or air to air HP. Not always an acceptable solution. Many people can't tolerate warm air heating.
It will be great to be able to offer a hydronic solution.
Seems we have reached the break even point between electricity ( for heat pump use) and oil at $2.50 gallon of oil and 17 cents KWH delivered.
Natural gas availabilty is limited.
16-02-2010, 06:35 AM #7
18-02-2010, 12:01 PM #8
19-02-2010, 08:05 AM #9
Way superior to the Ecodan. Far more models in the range in terms of duty and options on split system with hydrobox separate or combined called the monobloc. They also do a High temp version bringing water off at 80deg, so products for new build and retrofit. Also a good range of water tanks.
19-02-2010, 10:37 PM #10
20-02-2010, 09:59 PM #11
15-07-2010, 11:08 PM #12
You say that it does not have capacity drop but all heat pumps have capacity drop, it is how you market it and how you understand it.
The way that ecodan get away with this is that it may have a constant heat output but if you look at the technical data for the unit it is a larger unit which is labelled up as a smaller one.
When the capacity starts to drop the input power goes up hence the constant heat output but the power in goes up and the COP comes down.
It is just how you want to market it really, technical data books tell the truth....most of the time.
Vrv
By tgoonter in forum Air ConditioningReplies: 4Last Post: 11-01-2011, 06:25 AM -
Daikin Altherma Rotex HPSU + Sanicube Hydrocube
By hsmith in forum Heat PumpsReplies: 2Last Post: 15-07-2010, 10:44 PM -
new Daikin: 1 of 4 units doesn't heat
By AustrianinParis in forum Air ConditioningReplies: 8Last Post: 05-10-2008, 05:41 PM -
Daikin a/c units.
By rick in forum Air ConditioningReplies: 59Last Post: 18-02-2008, 09:22 PM -
Decommissioning Daikin Units
By BarKeg in forum Air ConditioningReplies: 2Last Post: 15-02-2008, 12:42 AM
