    lutti's Avatar
    lutti Guest
    Smile DIY Inverter Mitsubishi SRK25ZIX-S heat pump
    Is it possible to convert air of Mitsubishi SRK25 ZRX-S to water-heat pump? I want to
    control the work of that pump with the original control circuit of an inner part of
    a condensing unit?
    The problem is with the speed indicator of the fan. Is there anybody who has got
    such an experience?
    Jun 2007
    Cyprus
    73
    252
    Re: DIY Inverter Mitsubishi SRK25ZIX-S heat pump
    Lutti,
    I am sorry, this is not meant to be direspectful, but I am not sure what your question is. Are you asking if a standard AC/heat pump air to air can be converted to air to water? If so the answer is yes with an appropriate heat exchanger.
    lutti's Avatar
    lutti Guest
    Hello Fridge Doctor,
    i have already done what you mean. but now i want to convert inverter air to air heat pump to water system. i have all the details for this project including a plate heat exchanger. The problem is that the indoor unit controls a fan speed and gets a feedback signal from this fan. Maybe there is any testmode , jumper, or something that i can switch this rotor feedback off!
  1. New Heat Pump Forum
    By Argus in forum Heat Pumps
    Last Post: 10-04-2010, 09:12 AM
  2. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  3. Heat pump with inverter technology for Motorhomes
    By back2space in forum Air Conditioning
    Last Post: 23-01-2009, 11:58 AM
  4. Will this heat pump work?
    By goodguy in forum Heat Pumps
    Last Post: 08-03-2008, 04:14 PM
  5. mitsubishi heat pump
    By Mark in forum Air Conditioning
    Last Post: 17-01-2004, 10:43 AM
