Results 1 to 9 of 9
Thread: 50kg Blast Chiller
03-02-2005, 02:04 PM #1
50kg Blast Chiller
Can anyone recommend a 50kg blast chiller please?
Fosters and Williams prices are above budget, and i don't know of any other makes in this size.
Any pointers would be appreciated.
Eggs
03-02-2005, 07:44 PM #2
Re: 50kg Blast Chiller
Why not make one yourselves in PU panels, like found on www.isobar.be , mount a big evaporator in it and a compressor. Eliwell, Dixell, Carel have special controllers for this.
It will cost you a lot less then pre-made units.
PS, 50 kg blast chiller, what entering temperature has the product, cooling time and desired end temperature?It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
03-02-2005, 07:51 PM #3
Good idea Peter.
I like your attitude.
Also, if you use a speed contoller for the conveing belt, out temp of the product can be controlled.
Chemi
03-02-2005, 09:12 PM #4
Thanks for the replys chaps, but this too adventurous for me. I just want a low priced, off the shelf cabinet like this:
03-02-2005, 09:25 PM #5
ooops!
Try again.
eggs
04-02-2005, 06:38 AM #6
Zanussi do a range
http://www.zanussiprofessional.com/c...nglish&ua=MSIE
they tend to be priced slightly lower
dealers
http://www.zanussiprofessional.com/c...er_locator.jsp
cheers
richard
04-02-2005, 04:33 PM #7
Thanks Richard.
I tried my local dealer.
OUCH!!!!!!!, on the telephone i must sound like a piece of ass meat, waiting to be beasted.
Retail £6866, special price for me, £4806.
Looks like i'll be buying the Williams then.
Thanks for the help anyway.
eggs
04-02-2005, 08:31 PM #8
Special price 4806 £? or +/- 8400 €
What compressor is on that cabinet eggs? Something around 5 HP?
Well, a cabinet with door for 3 x 4 x 7 ft will cost you +/-1.000 Euro, unit 1800, Evaporator 1000 €, switch cupboard 1000 € and 800 € to make it (on which you will earn then even on that amount) = +/- 6.000 € to 6.500 €
It's then made like you wish it has to be made.It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
05-02-2005, 09:23 AM #9
Caravell Universal Blast Chiller and Freezer Cabinets
CUB60C Chiller Stainless Steel
CUB60C/F Chiller/Freezer Stainless Steel
CUB100C Chiller Stainless Steel
CUB100C/F Chiller/Freezer Stainless Steel
CUB102C Chiller Stainless Steel
CUB102C/F Chiller/Freezer Stainless Steel
Suitable for use in conjunction with combination ovens.
Loading... Please wait...
Technical specifications:Name Dimensions W x D x H (Internal) Chilling Capacity KG Freezing Capacity KG
CUB102C 1325x1145x1810 70
CUB100C/F 820x870x1810 36 25
CUB100C 820x870x1810 36
CUB60C/F 820x870x1595 22 15
CUB60C 820x870x1595 22
Dunham Bush Chiller Alarm
By Regulator in forum Air ConditioningReplies: 11Last Post: 08-12-2010, 01:42 AM -
DIY aquarium chiller
By BarraCuda in forum Technical DiscussionsReplies: 18Last Post: 06-10-2010, 11:02 PM -
York Screw Chiller How low will it go?????
By bruceboldy in forum Industrial CompressorsReplies: 11Last Post: 10-08-2007, 10:29 PM -
Chiller fault
By iceman007 in forum Trouble ShootingReplies: 9Last Post: 27-06-2006, 06:15 AM -
closed loop chiller
By bender in forum Trouble ShootingReplies: 8Last Post: 02-01-2003, 01:32 PM
