Results 1 to 1 of 1
Thread: Horse power rating
03-02-2005, 10:52 AM #1
Horse power rating
?Horsepower? is an Imperial unit that seems to have crept into the refrigeration and Air Conditioning industry as a nominal measure of power.
When applied to the mechanical / refrigeration capacity of compressors via the theoretical electrical input of the motor it doesn?t tell you anything about the duty you are getting.
The Japanese and Korean spilt system purveyors are very keen on describing their units in horsepower. If you compare a range of manufacturer?s systems at a single nominal HP rating, the actual capacities in kW will vary considerably.
Please have a look at the attached link from AREMA in Australia.
http://www.arema.com.au/HP_fact_sheet.pdf
Capacity is best measured in kW (or Btu/hr, if you prefer) at a known or predicted condition.
________
homemade vaporizerLast edited by Argus; 07-02-2011 at 08:13 AM.
compressor horse power
By ewart in forum Industrial CompressorsReplies: 9Last Post: 27-07-2009, 05:39 PM -
Daikin KRP2A61 Card Power consumption
By EddieC in forum Air ConditioningReplies: 5Last Post: 19-08-2006, 04:08 PM -
NEW 3-Phase IGBT Inverter Power IC
By theberes in forum New TechnologiesReplies: 14Last Post: 01-03-2004, 01:10 AM -
EEV's and their usefullness for low power applications
By DaBit in forum New TechnologiesReplies: 7Last Post: 18-08-2003, 09:11 AM -
motor horse power
By mtoto in forum FundamentalsReplies: 4Last Post: 05-06-2002, 03:32 AM
