    Feb 2010
    usa
    21
    slide valve modification
    Does anyone have good drawings for modifying Mycom slide valves to change vi. Have 200, 250, and 320 that need to be 2.6.
    3,362
    Re: slide valve modification
    salamander ,
    Mycom should be able to supply this to you no problem , especially if you buy spares off them .
    Both slide valve and discharge end housing port have to be modified .
    From what Vi are you converting from out of interest and why ?
    Feb 2010
    new zealand
    42
    67
    15
    what are your running specs i got a chart in the car i could tell you what port to run, or with a bit of effort i can send the info via fax?
    Feb 2010
    usa
    21
    I got the numbers for all but the 320. Customer is changing to thermosyphon, it's all about efficiency. So far I'm not intending to modify the discharge, but I haven't seen anything on the 320.
    3,362
    Whats t/syphon got to do with Vi ?
    Feb 2010
    usa
    21
    I'm not sure about the math, but I know we're saving $. I've recently moved from process to NH3. Enjoy the papas fritas.
    3,362
    So what type of oil cooling did you have before t/syhpon ?
  1. Slide valve wear on Grasso screw after just 54000 Hrs
    By Lodiev in forum Technical Speculations
    Last Post: 14-09-2009, 01:21 PM
  2. calibrating slide valve on rxf control pannel
    By marley in forum Industrial
    Last Post: 30-08-2009, 06:26 PM
  3. LEV does not open
    By Yuri B. in forum Air Conditioning
    Last Post: 19-07-2009, 02:37 PM
  4. FRICK TDSH 233 Slide Valve and guide damaged
    By 404cab in forum Industrial Compressors
    Last Post: 30-07-2008, 11:24 PM
  5. Autoloading slide valve for Screw compressor
    By screw_geek in forum Industrial Compressors
    Last Post: 04-04-2008, 03:47 AM
