Page 2 of 2 FirstFirst 12
Results 51 to 52 of 52
  1. #51
    Aug 2009
    New Zealand
    2,554
    26
    Re: TEV on long liquid line, liquid hammer
    Practically pressure from liquid would be approx 10barg at 20C ambient, so pressure pulses would less.
    What Chef calcs did prove was pressure spikes sure can be a problem (breaking of piping) a common problem!
    I would hope the client has installed an Alarm system, surely he did not loose product a second time?
    There are thousands of system with long pipes runs as you have described.
    (I remember Littlewoods systems were always like this 25 years ago, much longer pipe runs)
    In court, I do not know how you can prove negligence. It may not be a perfect design, but what is!
    On the original call the tech, added 60Kgs of refrigerant (seems like alot), was it removed. maybe there was a leak, some moisture had been drawn in causing the valves to block. No reduction it temp.
    Was a leak found, were driers replaced at each service call (technical should always be done)
    this you can find on the service invoices.
    You can not blame the tech for the first lot of product lose, as already unfrozen before he arrived.
  2. #52
    Oct 2003
    5,630
    34
    I have 1 week time to give my report and I will add this as an additional advice. Thanks for you ongoing support you both.
  1. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  2. Suction gas <-> liquid line heat exchange and performance gains
    Last Post: 18-05-2010, 01:52 PM
  3. high liquid line pressure?
    By TECH TIM in forum Commercial
    Last Post: 09-05-2009, 05:36 PM
  4. liquid return through suction line after hot gas defrost period
    By coldkeeper1 in forum Supermarket Refrigeration
    Last Post: 19-06-2008, 10:07 PM
  5. subcooling liquid line
    By mac_J in forum Technical Discussions
    Last Post: 15-02-2008, 10:10 PM
