09-02-2010, 01:10 PM #1
Fault on samsung f/f SRS-S2028CVW
I have a SR-S2026CVW american style FF and experiencing the following problems:
The display reads -20 for the freezer and 2 for the fridge, however inside both compartments feel warm. I placed in a thermometer and found the freezer to be -5 and the fridge to be +5. I carried out an Irish reset (power off/on) and the display then read the correct temperatures and the compressor started up. This woked fine until it reached temperature and x amount of time later, I checked and it was warm inside again.Could someone please advise what the problem could be.
10-02-2010, 08:45 AM #2
Re: Fault on samsung f/f SRS-S2028CVW
the system is lockingout,may be the system reaching below set points due diffective controller,the controller to be caliberated or replaced
10-02-2010, 06:40 PM #3
defrost heater likely to be open circuit
14-02-2010, 12:46 PM #4
I have a samsung srs2026cvw with the usual (it seems) defrost problem. the panel reads -20 but the internal temp on the freezer is -5 and getting warmer. can anyone offer advice on this and also possibly email a service manual for this model. many thanks. simon@kitchenmakeover.org.uk
