Thread: gas change
03-02-2010, 07:17 PM #1
gas change
I am specifying a shop reform which includes new AC splits
The existing units use 407c and we wish to leave the pipework in place. the new units (same size) use 410a
DO we need to specify any proceedures (cleaning etc)?
Grateful for any advice
George
03-02-2010, 07:20 PM #2
Re: gas change
Check for oil compatibility between the two systems.
Cleaning of the pipework would be good idea anyway.
Is pipework suitable for R410a pressures?Brian - Newton Abbot, Devon, UK
04-02-2010, 07:01 AM #3
Re: gas change
I assume you are talking about compressor oil and my (limited!) understanding suggests that 407 and 410 sytems dictate similar/compatible oils anyway.
The installers have intimated that purging the pipes with 410 will clear most of any residue and they usually do this.
I do not want to cut corners but todays inviroment precludes contract losing overkill.
Thank you for your promt reply to my first post
Kind regards
George
04-02-2010, 05:35 PM #4
04-02-2010, 06:40 PM #5
Basics or is it?
By Fett in forum FundamentalsReplies: 17Last Post: 10-09-2009, 01:45 AM -
Oil change problem
By murray75 in forum Technical DiscussionsReplies: 2Last Post: 06-02-2009, 07:20 AM -
Change over 2 outdoor unit
By bach in forum Air ConditioningReplies: 8Last Post: 08-06-2008, 06:55 PM -
Freus, water cooled, change gas?
By Dennis Williams in forum Air ConditioningReplies: 2Last Post: 27-06-2007, 07:04 PM -
love to hear from the pros.(gas change)
By jamcool in forum RefrigerantsReplies: 9Last Post: 17-11-2006, 01:18 AM
