Results 1 to 14 of 14
Thread: Refco expansion valve tool
02-02-2010, 07:53 PM #1
Does anyone know where i can get hold of one of these?
They are used for checking EEV's whereby they can be manually opened or closed.
On a Sanyo unit that i've been working I've been working on a sanyo unit and in the manual it says to use this tool but i can't find anywhere that sells it.The difference between genius and stupidity is that genius has its limits.
Marc
02-02-2010, 07:56 PM #2
Re: Refco expansion valve tool
Javac UK is the usual source for Refco stuff
02-02-2010, 09:46 PM #3
I couldn't see it on their site so i've sent them an email,
ThanksThe difference between genius and stupidity is that genius has its limits.
Marc
03-02-2010, 06:37 AM #4
Hi Mark.
Let us know how you get on will you?
After reading your thread I downloaded their Complete Catalogue.
Nothing there as you say!
03-02-2010, 09:39 PM #5
Well i spoke to sanyo today and managed to get a refco part number.
I spoke to Javac and they had one in stock and are sending it to me.
I'll let you know if it fits the EEV's since they are a handy tool to have.The difference between genius and stupidity is that genius has its limits.
Marc
03-02-2010, 10:42 PM #6
If not at least it will something to talk about down the pub
06-02-2010, 05:08 PM #7
Well i received the solonoid valve magnet on friday and it looks like the 1 i already have for manually lifting solonoid valve heads but.... took it to site this morning and found that it fits.
I compared it to my other solonoid magnet and whereas that magnet is 15mm this is 18mm so happy daysThe difference between genius and stupidity is that genius has its limits.
Marc
06-02-2010, 10:38 PM #8
Hi Marc,
Have you tested the expansion valve magnet? How much was it? The standard solenoid valve magnets will not operate an expansion valve, they are very different.
The expansion valves come with 4 different sizes of stem, I’m sure daikin also sell a complete set of 4 expansion valve magnets as a service tool.
07-02-2010, 10:30 AM #9
Hi VRVIII,
I haven't tested that it works yet but i checked that it fitted over the head on a similar sanyo unit yesterday and it did.
It cost £15 plus postage from Javac UK and is the exact one that is in the Sanyo service manual.The difference between genius and stupidity is that genius has its limits.
Marc
07-02-2010, 11:51 AM #10
Hi Marc,
Thanks for the info, let us know how you get on when you get a chance to test it
How does the Sanyo manual tell you open the valve? By turning the magnet on valve stem or just by placing the magnet onto the stem?
One thing I have found when using these magnets is when fully closing EV by turning you can’t feel any extra resistance when valve is closed. This seems to result in over tightening of the valve and it can stick in closed position, you sometimes need to use the unit EV coil to release it.
The magnets aren’t as strong as the EV coil/motor, there are very strong EV magnets available from Japan but these range from £80 to £100 each depending on size
06-02-2010, 10:12 PM #11
All that for a magnet ! I thought we were going to get some magic gizmo here Marc,
Could have got them at HRP etc. I've had two sizes and before anyone pases comment I'm talking about the magnets.Brian - Newton Abbot, Devon, UK
06-02-2010, 10:16 PM #12
I've asked 3 different companies before and have always been told they only do one size......magic trick to follow
HRP... you could have told me Brian...that was the one company i didn't tryThe difference between genius and stupidity is that genius has its limits.
Marc
LEV does not open
By Yuri B. in forum Air ConditioningReplies: 7Last Post: 19-07-2009, 02:37 PM -
Actual Expansion Valve Process
By AastroGuru in forum FundamentalsReplies: 11Last Post: 03-02-2009, 09:53 AM -
Setting of Hand expansion valve
By Iceehot in forum NH3Replies: 7Last Post: 10-09-2008, 01:25 AM -
the function of the electronic expansion valve
By Crystal-426 in forum FundamentalsReplies: 10Last Post: 22-06-2008, 12:29 PM -
Need Divine Intervention - plugged drier or expansion valve?
By archibaldtuttle in forum Trouble ShootingReplies: 4Last Post: 08-06-2008, 06:52 PM
