    May 2009
    uk
    54
    7
    condensation on outside walls of freezer
    Hi i have a small walkin freezer about 2m square got terrible condensation on outside of walls no build up of ice on the inside the unit is housed outside
    Oct 2008
    mallorca, spain,
    69
    771
    13
    Re: condensation on outside walls of freezer
    try some insulation in the walls, or your insulation is wet, or there is something between the inside + outside skin and its tracking across that knock it down and start again
    Jan 2010
    Christchurch
    48
    28
    The presence of moisture or condensation on the walls outside is a clear indiction of the insulation being to thin or wet (I believe the latter), sometimes the joints inside the room haven't been sealed properly letting moisture in, the defrost cycle doesn't help as it tends to cause the air to expand and force moisture into the insulation (if no relief port is installed), the unit will be working harder as the load is increased, its a big job to dry out the insulation and seal it all back up again.
    Aug 2009
    New Zealand
    54
    2,556
    There are times when you just have to use the right technical terminology
    The freezeroom
    " IS F****D "
    Oct 2008
    mallorca, spain,
    69
    771
    13
    hey mad fridgie, I think you may be correct,
    Apr 2009
    israel
    44
    778
    13
    Quote Originally Posted by mad fridgie View Post
    The freezeroom
    " IS F****D "
    100 % correct!!!!
    THE DEFINITION OF A SMART PERSON IS ONE WHOM LEARNS FROM HIS MISTAKES!!!
  1. Blast Freezer Within Freezer
    By rickmor in forum Technical Discussions
    Last Post: 18-06-2009, 03:37 AM
  2. Hotpoint FFA71 Freezer High Temp Light / Fridge is Freezing
    By sumnerpa in forum Trouble Shooting
    Last Post: 19-08-2008, 03:16 PM
  3. R290, walls ice cream freezer
    By Andy W in forum Commercial
    Last Post: 22-06-2007, 07:49 PM
  4. condensation on light in freezer
    By ice cold in forum Supermarket Refrigeration
    Last Post: 20-05-2006, 05:16 PM
  5. walls freezer wiring diagram
    By andyh in forum Electrical
    Last Post: 19-01-2006, 09:21 PM
