    Dec 2004
    Weihai,China
    800
    sewage source heat pump issue
    Many cities use sawage resource heat pump for building air conditioning but there're headache for the heat exchanger fouling issue,esp the biological fouling. Any body know the advanced technology to overcome this issue? thanks in advance!
    regards
    LC
    Aug 2009
    New Zealand
    2,554
    Re: sewage source heat pump issue
    Scraped surface heat exchanger
    Mar 2009
    KZN, South Africa
    64
    2,212
    Not overly efficient, are these beasts, I'd suspect. Probably lots of maintenance.
    There would also be a few alternative technologies to manage this, I'd expect.
    There was a technology project a year-or-so back, that centred around heat-pumps that extracted their energy from sewerage. On the MW scale, as I remember - US-based company looking for new technology.
    Lc_shi are you perhaps involved in this?
    Aug 2009
    New Zealand
    2,554
    Quote Originally Posted by desA View Post
    Not found efficiency to be bad on a per meter of heat transfer surface area, but per space requirement is a different matter. A lot of space require compared to say a PHE of some sort.
    Maintence, not as much as you make think, modern nylon blades last for years, moter and gear box, i supose comes down to original sizing and build quality.
    on the negative if a large piece of crud does get stuck then strip down would be required.
    the next question should be what is the exact fouling problem, a part from the obvious "a large turd stuck up the pipe" and how this fouling is manafesting itself
  1. Capacity control
    By sparrow in forum Training
    Last Post: 18-01-2010, 07:49 PM
  2. water source heat pump
    By gramcor in forum Air Conditioning
    Last Post: 11-03-2008, 12:06 AM
  3. Air Source Heat Pump
    By anup in forum Fundamentals
    Last Post: 02-10-2005, 11:35 AM
  4. Mcquay water source heat pump
    By bernie in forum Air Conditioning
    Last Post: 10-02-2003, 01:53 AM
  5. Water Source Heat Pump
    By aliugur in forum Fundamentals
    Last Post: 02-06-2002, 03:24 PM
