    malaysia
    multi-temperature warehouse
    I am building a new warehouse that accomodates freezers (-18), chillers (1-4) and ambient (room temperature (generally around 30).
    Right now am having a tough time getting the a winning solution on receiving area, after pick and shipping area as products are of different temperature requirement.
    Anyone have any ideas how do the big distributors do it? As we get a lot of clients that order different temperature products at the same time.
    Please advice
    Nov 2004
    China
    176
    Re: multi-temperature warehouse
    Receiving and shipping can be 10 to 15 degrees. Product should not spend much time there so temperature rise from storage to truck is not significant. i usually design evaporators with at least 7-9 degrees TD for this area. Suction then goes to the medium temperature compressors.
    malaysia
    Hi Charlie,
    do they pick orders straight from respective storage direct to shipping area to consolidate?
    or do they place products at after-pick area in each storage room and move the products out to the shipping area and then for loading?
    lastly, no problem with the dry products at between 10-15?
    malaysia
    Quote Originally Posted by charlie n View Post
    what do you mean 7-9 degrees TD? please explain more as I am not a technical person.
    thanks.
    Also i have heard of way to reuse the cold air from freezer/chiller for other rooms - can it be applied in this case to the 10-15 degrees area? using recycle air from freezer and chiller.
    thanks
    Nov 2004
    China
    176
    Air recycle from cold areas to warm areas is the worst possible way to efficiently cool a space.
    Most distribution warehouses ship directly from storage to truck. A small after pick area may be necessary if you have less than pallet order picking. If so, 1 to 4 degrees is fine for this.
    Dry products can safely transit the 10 to 15 degree loading dock.
  1. Replies: 12
    Last Post: 27-03-2011, 04:12 AM
  2. Superheat and Subcooling
    By Chunk in forum Fundamentals
    Last Post: 15-01-2011, 01:24 AM
  3. LG heat pump problem
    By back2space in forum Heat Pumps
    Last Post: 01-02-2009, 11:23 PM
  4. Thermo King OptiSet
    By REEFER-TEK in forum Transport
    Last Post: 06-12-2007, 07:23 PM
  5. Article in ACH&R News
    By Gary in forum Fundamentals
    Last Post: 20-05-2003, 12:27 AM
